Transmission coolers - Team Camaro Tech
Old Feb 17th, 13, 08:18 AM
stevo camaro's Avatar
stevo camaro stevo camaro is offline
Question Transmission coolers
What would be a adequate cooler size for a T-400 without running it in series with the radiator? Stand alone cooler. I have a 15X7X 1/2" but it seems small. They say for 15K GVW vehicle but I'm assuming that's running it in series with radiator.
Any thoughts? I'll be putting it in front of this radiator.
Click image for larger version
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 Salvaged RS pro street project, ready for floors & motor.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
77 Trans Am, complete, sitting.
55 210 post, 2 door.
Some mornings, it's just not worth chewing thru the leather straps"
Old Feb 17th, 13, 09:40 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Re: Transmission coolers
Who is this Stevo dude? Hey Steve, hope all is well out there in Calif.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Feb 17th, 13, 10:10 AM
X-77 keith X-77 keith is offline
keith
I never run my coolers through the rad. If it goes through the rad your trans temp will get no lower than the temp of your engine coolent. Temp is the killer of an auto trans. If you are not running a large stahl converter it should be fine.
Old Feb 17th, 13, 12:28 PM
BPOS BPOS is offline
Al
Take a look at the B&M stacked plate supercoolers. Looks like you have tons of room so I'd get a biggen. Depending on how you plan to run the piping, they have either hose barb or NPT fittings. 15 x 7 x 1/2" is pretty good sized - but you didn't say if tube & fin or stacked plate. I believe the stacked plate are more effective.
http://www.summitracing.com/search/b...s?autoview=SKU
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Feb 17th, 13, 04:29 PM
I know, stevo who. LOL
Been working on the 454 car again, making lots of progress.
No high stall converter. It's a Hayden tube & fin cooler. I have 2 laying around the shop and will use one if adequate. I've got the hard lines off the trans running to the bottom of radiator and would just run short lengths of hose to the barbed ends of the cooler.
Here's a newer pic of the beast. LOL
Name:	454 cam fans.jpg
Old Feb 17th, 13, 05:25 PM
Everett#2390's Avatar
<Jake 68's Rule
Add the cooler, but fill it from the bottom to purge out the air in the cooling tubes.
Yes, you can use the trans hoses, Hayden and B&M make them. Just change them every four years, like we righteously do with the cooling hoses...
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
