Dash cluster ground - Team Camaro Tech
Old Feb 17th, 13, 01:19 PM
Mike68RS Mike68RS is offline
Mike
Default Dash cluster ground
I need to add a ground to my dash cluster. Does it matter which screw I connect the ground wire to? The dash is already installed now, so it would be easier if I could attach it to the one on the far left, which i can get to from the back, without removing the cluster.
Thanks,
Mike
Old Feb 17th, 13, 03:56 PM
69-Pace's Avatar
69-Pace 69-Pace is online now
Default Re: Dash cluster ground
Does not make a difference which one you use.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear
http://69pace.blogspot.com/
Old Feb 17th, 13, 04:03 PM
john68 john68 is online now
John
True, but if the ground does't go to the bright light socket it won't work.
Old Feb 17th, 13, 04:35 PM
Mike
Thanks guys. John, it looks like the socket is grounded to the cluster housing by a metal strap, so if I use that far left screw I should be good, correct?
Thanks again.
Mike
Old Feb 17th, 13, 04:48 PM
Sauron67MM Sauron67MM is online now
Scott
Thanks again.
Mike
That metal strap grounds the whole cluster through contact with the dash and center attachment screw. Are you adding a second ground as insurance?
Old Feb 17th, 13, 05:11 PM
1968RallySport's Avatar
1968RallySport 1968RallySport is offline
Daryl
Mike, here's a picture of my ground strap. It looks like you already may have the strap. Not sure why you want to another? It will ground when the cluster is installed.
Old Feb 17th, 13, 05:36 PM
Mike
I guess I'm confused. Yes, I do have that strap already attached and from your help I see how it grounds with the center screw, but in the AIM, there is a seperate ground wire going from the cluster to the pedal assembly. That is what I am trying to add.
Mike
Old Feb 18th, 13, 04:51 PM
oakster oakster is offline
The center screw that grounds that strap often leads to a faulty ground. Doing what Mike suggests is great insurance to make sure you have a good ground. Well worth the effort IMO.
1967 Camaro RS 350, Tremec 5spd, Hotchkis, Frame off
Bought it November 2003
Rebuilt it 2004
Almost done January 2006
Old Feb 19th, 13, 06:27 PM
67RSSS's Avatar
67RSSS 67RSSS is offline
Chris
I would also recommend the secound ground wire to the firewall! These grounds are famous for causing grief and causing intermitent dash lights. Do it while its apart and add the star washer under the screw head to secure to firewall and never worry again about the dash ground.
67RSSS highly Optioned
383 ci,
AFR 195 heads
TKO 600 Extreme, Centerforce dual friction clutch,12bolt 3:73 gears.
