Oil pan for zz427 in 68 - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Feb 24th, 13, 05:27 PM
Long Island Mouse Long Island Mouse is offline
Bill
Default Oil pan for zz427 in 68
I am putting a zz427 in my 68. it had a396 in it. the drag link rubs the pan when turning. other wise there is about 1/8 clearance. does any one have part numbers for pans that work? I would like to retain oil capacity , 6 qts.
Old Feb 24th, 13, 06:18 PM
TJS69 TJS69 is offline
Tom
Smile Re: Oil pan for zz427 in 68
Are you using the 396 oil pan ?
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Feb 24th, 13, 08:13 PM
Bill
Default Re: Oil pan for zz427 in 68
we put the engine in with the pan it came with, to check the fitment of headers, will the gen IV oil pan fit the zz427?
Old Feb 25th, 13, 05:20 AM
cstraub cstraub is offline
Chris
You will need a 1 pc rear seal pan. B&B has one that fits.
Chris
www.straubtechnologies.com
Old Feb 25th, 13, 08:43 AM
Bill
pan will not fit , front is different, has anyone had luck with different pan GMPP says 12495360 will fit but it is 4 qt and will require changing pick up
Old Feb 25th, 13, 08:45 AM
novaderrik novaderrik is offline
is it an option to just clearance the oil pan a bit to clear the linkage with a chunk of pipe and a heavy ball peen Ford tool?
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Old Feb 25th, 13, 08:52 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
John
Can you simply raise the motor a 1/4" or so to clear?
69 Pro Tour - LS3/T56
69 Pro Tour - LS7/T56 (SOLD)
69 LS7 Pro Tour #2(BUILDING)
69 Z28/RS Tribute355/5 Speed (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
69 Camaro 406 SBC/TH400 (SOLD)
Old Feb 25th, 13, 09:56 AM
5speed502's Avatar
5speed502 5speed502 is offline
john
That sounds like the correct part no. I ordered for my 69, but I will have to check. I ordered mine from Summit Racing and got the pickup tube with it. I believe it is a GM part as well. I will try to check this.
Beware the lollipop of mediocrity... Lick it once and you will suck forever!
Check out my Camaro build at
http://smg.photobucket.com/albums/v7...s/69%20camaro/
Old Feb 27th, 13, 03:54 AM
5speed502's Avatar
john
Well, unfortunately I am undergoing a major remodel in my home and I cannot find anything pertinent to what I am interested in....
Can someone else help out with a part no. for the correct fitting oil pan?
Sorry to let you down...
Old Feb 27th, 13, 09:18 AM
JayBird JayBird is offline
I used a Milodon #30975. It requires pickup and I would recommend buying windage tray. Windage tray free's up 8-10hp.
Call Milodon tech. They are very helpful. I got everything thru Jegs or Summit. Cant recall now.
69 SS
69 project for my wife - SS 396, Glacier blue
http://www.camaros.net/forums/showthread.php?t=176706
  #11
Old Feb 27th, 13, 05:13 PM
JimmyC's Avatar
JimmyC JimmyC is offline
Jim
Dropped a 496 in a 67 Chevelle few months ago using Milodon pan and had to use a Moroso shim kit for pan clearance. Shims might work for your application.
I'm very interested in this thread also as I am getting ready to set a ZZ427 in my 69 Camaro.
69 ZZ427 RS resto-mod in progress.
Build Pics ---> http://www.camaros.net/forums/album.php?albumid=727
69 X77 Z28 406 TH400.
69 Pre X RS Z28 in boxes.
67 Chevelle 496 TH400.
64 Nova 396 TH350.
Gold Member #1164
Jim
  #12
Old Feb 27th, 13, 06:37 PM
Bill
Muscle Car is doing a NOPO to COPO show and putting the anniversary 427 in a 69.the engines are basically the same. you might want to watch it .
I am going to replace the idler and pitman arms with 5 3/4 ones. this may give me 1/2 inch clearance off the pan front. if that doesn't work I guess I'll have to pull the pan.
  #13
Old Mar 1st, 13, 05:26 PM
Rally Sport Rally Sport is offline
Tech Team
Kent
I used the following in my 427.
I ordered my oil pan and pump from Pace performance:
Pan part number 12495360 Standard 5 quart pan
Pump part number 66896
Its been in since Jan 09 no problems
  #14
Old Mar 2nd, 13, 01:23 PM
Bill
Rally Sport, Jeg's carries this pan as a kit that comes with 4 main cap bolts. Did you need to replace anything besides the gasket , pan, pick up and dip stick? 12495360 is listed as a 4 qt are you counting the filter oil for 5? Thanks .Bill
  #15
Old Mar 3rd, 13, 02:52 PM
5speed502's Avatar
john
Just found the receipt for my oil pan I installed. Same Summit part no. Fits perfect, no clearance issues.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: Oil pan for zz427 in 68
Location
Location
First Name
Human Verification
