Have A "U" In my 67 camaro - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Feb 24th, 13, 05:53 PM
casper65 casper65 is offline
steve
Default Have A "U" In my 67 camaro
hello,
I inherited a 67 camaro vin 12x377U10xxxx. I have done a lot of research and found this car to have been built in sept of 1966 which was before norwood was fully of line producing camaros according to everything I have read. This is the first Camaro I have found with a "U" in the VIN. I have even checked the two other hiden partial numbers and came up with the same. The door post vin has the rosette rivet and same 7U10 vin number. Any thoughts?
Old Feb 24th, 13, 05:54 PM
1968RallySport's Avatar
1968RallySport 1968RallySport is offline
Daryl
Default Re: Have A "U" In my 67 camaro
What's the complete VIN?
Old Feb 24th, 13, 06:05 PM
1969 RS/SS DROPTOP 1969 RS/SS DROPTOP is offline
Paul
Thumbs up Re: Have A "U" In my 67 camaro
Welcome to team camaro!!
Old Feb 24th, 13, 06:31 PM
steve
have you ever seen a "U" in a camaro VIN? Last time I gave a full VIN someone used it to register there car and I ghad a hard time with mine. had to have the police come and verify my vin and then send it off to the DMV and lost the org, VIN number. the x are other numbers
Old Feb 24th, 13, 07:44 PM
DjD's Avatar
DjD DjD is offline
Dennis
People post vin's here every day, I don't know how someone can use just any vin to register a car, you have to have a title to register a car and in most states a physical inspection is required to get a car title...
I have never seen a U on a Camaro vin it should be an L or N... As for Sept '66 production there were about 15,000 Camaros produced by the end of Sept '66 and I believe very early cars are known and have L or N in the vin.
Pictures of the VIN and Cowl Tag would go a long way in validating your car...
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Feb 25th, 13, 05:43 AM
rogerh rogerh is online now
If the VIN has a U then shouldn't the trim tag also have the U? Everyone likes pictures so a picture of the trim tag would make the OP's point about a U in the VIN.
Roger
1967 Camaro SS/RS 350/295HP Coupe. First and only owner.
Old Feb 25th, 13, 06:00 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
I might be very foggy when Im typing this... but I seem to recall that some cars that were originally shipped overseas to foreign countries, had their VIN assigned in that country when it arrived and used different letters than the typical N or L for cars sold in the U.S. Im betting Kurt or someone from CRG will have an answer to this but its perfectly ok to post VIN numbers here. They are visible from 68 forward in time thru the windshield anyway, people can see VIN's anytime they want.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Feb 25th, 13, 07:03 AM
DjD's Avatar
DjD DjD is offline
Dennis
Some very good and detailed info on foreign assembly and exported cars with respect to vin and cowl tags...
http://www.camaros.org/foreign.shtml
...Dennis
White Wonder
The Nova
Photo Album
Old Feb 25th, 13, 07:17 AM
bertfam bertfam is offline
Ed
I'd need to see a picture of the VIN tag and the Trim Tag.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
My Home Page
My contact info
Camaro Research Group
Old Feb 25th, 13, 08:18 AM
buenymayor buenymayor is offline
Steve, if you are nervous about posting your VIN number, PM the pictures to bertfarm or KurtS. They are 2 of the resident experts here, and will keep everything confidential if you want.
Experience...... It's what you get when you didn't get what you wanted.
http://camaro.bertke-one.com/teamcam...%20Camaro.html
Old Feb 25th, 13, 09:47 AM
Mark C Mark C is offline
Mark
U is the code for a Lordstown build car. In 67 Lordstown build Bel Airs, Caprices, Impalas, and Firebirds. None of which have a VIN sequence of 12X377 in them.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My Engine Compartment
Old Feb 25th, 13, 09:57 AM
DjD's Avatar
DjD DjD is offline
Dennis
Mark is some of this info wrong then or stated in such a way as to allow coming to incorrect conclusions? I'm seeing all '67 firebird coupes from Lordstown would be 123377U and other Chevys could be that way too...
http://www.transamworld.com/1genvins.php
...Dennis
White Wonder
The Nova
Photo Album
Old Feb 25th, 13, 10:14 AM
Ed
Dennis, all Pontiac model VIN's started with the number 2, so a 1967 Firebird built in Lordstown should be 223377U (Coupe) or 223677U (Convertible). The Firebird format didn't use the engine designation like the Camaro did, so all Coupes were 22337 and all Convertibles were 22367 regardless of the engine. The engine designation was actually part of the last 6 numbers. 1xxxxx would be a V8 and 6xxxxx would be a 6 cylinder.
The decoder you linked to is correct, but a bit confusing.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
My Home Page
My contact info
bcm66's Avatar
bcm66 bcm66 is online now
Bryon / Big B
Let's see a VIN tag pic and picture of the cowl tag. Also the partial VIN stamps.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Feb 25th, 13, 01:55 PM
steve
DJD
I don't have the cowl tag just the vin tag on the door post. I will get a pic and send it out. I will also get a pic of the part. vin from the cowl. This has been driving me nut for several years. I have had local camaro nuts tell me this is a Firebird. Then I pull the how come the partial vin does not match any listing for six or eight cyl.engines. Also had someone tell me it was a Nova cowl and vin. well that does not decode well either.
