Morel 4603 lifters BBC - Team Camaro Tech
Old Feb 25th, 13, 09:38 AM
DT DT is offline
Donny
Default Morel 4603 lifters BBC
Anyone using Morel lifters 4603 on a BBC? What pushrods are you using ???
396 X66 LeMans Blue, M20, 373 ...
Old Feb 25th, 13, 10:30 AM
cstraub cstraub is offline
Chris
Default Re: Morel 4603 lifters BBC
MOrel lifters are built to GM factor height. If you have aftermarket heads you need to measure the pushrods. I recommend a 3/8" with a swedged end.
OEM heads would be around 7.800 and 8.650" in length.
Chris
www.straubtechnologies.com
Old Feb 25th, 13, 11:37 AM
DT DT is offline
Donny
Thx, I have aluminum heads.
Old Feb 25th, 13, 11:42 AM
RSSSfanatic RSSSfanatic is offline
Tom
Best bet would be to get some adjustable check pushrods and some lighter check springs for the heads and use the mid-lift method to select the correct length pushrods. You can have custom length pushrods made up in any length you need from Trend and others. Google "midlift method for valvetrain geometry" for more information on this. If no luck, PM me and I can email a couple of PDF documents that explain it pretty thoroughly.
1967 RS/SS 350 Conv - triple black, 4sp, tach & gauges
1969 VN-built RS/SS 396 Conv - Garnet Red/Black, 4-sp, tach & gauges
Old Feb 25th, 13, 12:03 PM
DT DT is offline
Donny
Hey thanks Tom. I will check it out.
Old Feb 25th, 13, 02:04 PM
67RS502 67RS502 is offline
Chris whats your opinion on using check springs?
I always use the real springs, but just wondering...
67 camaro 373s:
420 - 641hp HRcam 1.40, 9.90 @ 135
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
Old Feb 27th, 13, 08:13 AM
Chris
I like using the real world set up also.
Sorry I missed this post of yours.
Chris
Old Feb 27th, 13, 11:43 AM
Tom
Chris, I assume you use a solid lifter of some type to keep the plunger from being compressed? What is a good substitute for the Morel hydraulics?
Old Feb 27th, 13, 11:49 AM
DT DT is offline
Donny
Talk about thread Hijacking!!!
Old Feb 27th, 13, 11:57 AM
Tom
Sorry, wasn't my intention to hijack - I thought it was related to the original post since you need to determine your correct pushrod length. Some people use check springs in the heads when doing this because the regular springs will compress the plungers and throw the reading off. I'll step off since you apparently don't need / want my help.
Old Feb 27th, 13, 12:00 PM
Chris
YOu can use a solid roller and then measure the distance using a .312" check ball. Morel has there measurements posted on the site. Subtract the difference and you have your pushrod length.
Morel's have .141 to .143" worth of plunger travel.
Chris
Old Feb 28th, 13, 08:17 AM
now for a real hijack
Chris
you were doing some spintronon girly roller lifters testing
can you post some info on your R&D?
valve weight, spring pressure, rpm ...
or is it top secret stuff that I'll only get when you do my next cam (with a big heavy intake valve)?
67 camaro 373s:
62 Nova
224/224 HR cam
1.57 10.97 @ 121.2
Old Feb 28th, 13, 08:37 AM
DT DT is offline
Donny
Chris
Time to grow up I think.
Old Feb 28th, 13, 09:04 AM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
Some of the best threads are the ones that get hijacked. Good stuff...
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Feb 28th, 13, 09:08 AM
well it is a hijack from the original post... hope the op doesnt mind
but a serious question about the spintron testing, a good technical subject, dont you think?
and I'm just givin Chris a hard time about my next engine project, which he will be doing the valvetrain on... need to throw more of these guys in next time so you guys dont take me so serious.
67 camaro 373s:
62 Nova
224/224 HR cam
1.57 10.97 @ 121.2
