69 camaro tail light wiring - Team Camaro Tech
Old Feb 25th, 13, 12:59 PM
chevy_guy69 chevy_guy69 is offline
Gabe
Default 69 camaro tail light wiring
hi, i need some help with wiring my tail lights. i've looked through alot of threads and i can not find an answer. this is my problem, my tail lights, turns signals and back up lights are very dim with turn signal on or 4-way on. my brake lights work but are dim as well. so this is what i found out..... if i touch the metal clips on the light bulb socket to a ground the light becomes bright. what is supposed to ground these? or do i have an incorrect harness? this is a fresh build so i dont know if the harness is correct. thanks for any help.
Old Feb 25th, 13, 01:07 PM
freezined freezined is offline
Ed
Default Re: 69 camaro tail light wiring
http://search.yahoo.com/r/_ylt=A0oGd...fr=yfp-t-900-s
There should be a ground wire coming off the harness that grounds to the trunk latch support, where the wire comes off for the license plate light.
Old Feb 25th, 13, 01:13 PM
Gabe
there is a ground and it is connected, if it isnt connected the lights will not work. so are the metal clips on the bulb socket just there to hold the socket into the housing?
Old Feb 25th, 13, 01:18 PM
Hotch Hotch is offline
Team Member
John
"Coming off" not disconnected. The ground is likely loose or corroded and creating resistance. Check with an ohm meter.
69 SS396 X66 / 4Spd / FATHOM GREEN
Old Feb 25th, 13, 01:26 PM
Ed
Interesting, you're right that's it's a bad ground, on a 69 the metal clips are just for retention to the plastic housing. If you run a wire from the metal clip to the grounding point does it help? 1st thoughts are weak ground, did they use a star washer or clean paint under ground? Sounds like a bad ground wire or something funky in the harness. Can you check the resistance between the metal clip and the ground wire?
Old Feb 25th, 13, 01:32 PM
Everett#2390's Avatar
<Jake 68's Rule
The sockets clip into the bezel and bezel is fastened to the tail panel with palnuts, a stamped sheet metal nut. This is the ground path.
You may need to run a separate ground wire from either the bezel, pick a screw/nut on the bezel itself, or just might need a path from a palnut to the trunk ground connection.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Feb 25th, 13, 01:55 PM
Gabe
everett, that is what i was thinking but how does it ground through the plastic? is there some sort of metal strip im missing?
Old Feb 25th, 13, 03:19 PM
Gabe
anyone have any more info on this ?
Old Feb 25th, 13, 05:21 PM
<Jake 68's Rule
OE sockets are metal and fit into the metal part of the bezel.
Aftermarket sockets are plastic with two metal tabs supposedlty touching the metal bezel. The tabs are galvanized and sometimes do not make good contact, hence, the separate ground wire.
Old Feb 25th, 13, 06:12 PM
Ed
69 OEM tail light housings are plastic, there's not a metal strip on the 69's, I believe the 67 and 68 tail light housings are metal. As Everett suggested you could run a wire from the socket to mounting post for a good ground
Old Feb 25th, 13, 06:29 PM
Vega$69 Vega$69 is offline
Team Member
John
This is the way they are wired. As all grounds go to a common point and all of your lights are dim this issue is probably with the with a bad ground.
Take the wires loose. clean the contact rings and remove the paint to bare metal where the ground wires attach. A drop of motor oil and re-attach the wires nice and tight.
If you still have issues check the engine to body ground straps.
69 Pro Tour - LS7/T56 Building
C6ZO6 Vette Lemans Blue
69 Z28/RS Tribute
355/5 Speed(SOLD)
69 RS Clone
427/TH400(SOLD)
67 RS
ZZ502/5 Speed(SOLD)
69 Camaro
406 SBC/TH400(SOLD)
Old Feb 25th, 13, 06:54 PM
BPOS BPOS is offline
Al
Everett thinks that the 1st gen Camaro began and ended in 1968!
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Feb 25th, 13, 06:59 PM
Team Member
John
Haha. The 68 was the testing bed that helped them get 69s perfect.
69 Z28/RS Tribute
355/5 Speed(SOLD)
69 RS Clone
427/TH400(SOLD)
67 RS
ZZ502/5 Speed(SOLD)
69 Camaro
406 SBC/TH400(SOLD)
Old Feb 25th, 13, 09:26 PM
Gabe
thanks everyone for the advice. ive tried and tried everything except running a seperate ground from each bulb socket to trunk ground. i think i may buy a new light harness. can someone tell me if a 69 camaro harness has the input wires and a ground wire to each bulb?
Old Feb 26th, 13, 02:42 AM
69-Pace's Avatar
69-Pace 69-Pace is offline
Have you checked the obvious such as wrong bulbs? Is the tail light housing tight against the body for good ground path? If you ground the light by hand does it brighten up?
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear
http://69pace.blogspot.com/
