my interior dome lite stays on - Team Camaro Tech
Old Feb 26th, 13, 03:58 PM
NYJOE NYJOE is offline
Joe
Default my interior dome lite stays on
Anyone have a simple Interior Lights Schematic for my 1969 Camaro thanks
1969 SS 468 built by Jack Merkel Racing Engines of Hauppauge, NY
Turbo 400 with reverse valve body by Staria's Racing Transmissions of Centereach, NY
Ford 9 inch 389 gears
4 wheel disc brakes
Old Feb 26th, 13, 05:41 PM
Steiner Steiner is online now
Steiner
Default Re: my interior dome lite stays on
Emailed schematics to the aol address you have listed for the site.
Basically, the dome light always has 12V on one side. Turning the headlight switch all the way up or having one of the door plunger switches pop out provides ground to the other side. Likely causes are headlight switch turned too far, one or both door switches screwed too far in so they are not pushed in when the door closes, or wire popped off the back of one of the door switches and touching the car body.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Feb 26th, 13, 05:47 PM
69CamaroRT 69CamaroRT is offline
Robert
i have the same problem, but one of the protective sheath that covers the wire by the dome light is worn thru and touching the body resulting in the light staying on.
69 Camaro Z/28 RS 10A of 68. 50 S with 723 int. soon to be 302 with m21. BU 12 bolt posi. http://s190.photobucket.com/albums/z...view=slideshow
Old Feb 26th, 13, 05:50 PM
rogerh rogerh is offline
I would check the obvious which is the headlight switch. You know if you turn the headlight switch you can turn the dome light on or dim the dash lights. Then I would check each door switch. The door switches grounds the dome light circut to turn on the dome light.
Roger
http://images.search.yahoo.com/image...mb=KB1Y9kHz/0D
1967 Camaro SS/RS 350/295HP Coupe. First and only owner.
Old Feb 26th, 13, 06:08 PM
Joe
thanks guys i found the right door striker faulty
4 wheel disc brakes
Old Feb 26th, 13, 06:49 PM
Joe
next question is where does my reverse lights lite green wire come out to hook up to my trans switch
4 wheel disc brakes
Old Feb 26th, 13, 06:56 PM
Steiner
Check down on the base of the steering column.
538 lb-ft - 500 hp
www.cmengines.com
Old Feb 26th, 13, 07:32 PM
Joe
thanks
4 wheel disc brakes
