1969 Camaro Z28 Value? - Team Camaro Tech
What's it worth? & ebay discussions
Thread Tools Display Modes
Old Mar 23rd, 13, 10:56 AM
MrGrinch MrGrinch is offline
Default 1969 Camaro Z28 Value?
Hello,
I was wondering if I could get some opinions on the value of a 1969 Z28 without the original engine? The car is rust free and otherwise in great shape.
Thanks!
Old Mar 23rd, 13, 12:23 PM
camarodude67 camarodude67 is offline
Default Re: 1969 Camaro Z28 Value?
OK, we need to see a lot of pics of your car in order to verify that it is real and then a guesstimate on what it is worth. We know your Trim Tag is real but your car needs to be verified in order to place a value.
Jeff G.
69 Z/28 RallySport
69 Z/28
67 Vert RallySport
69 Vert
Old Mar 23rd, 13, 12:52 PM
Jeff G.
69 Z/28 RallySport
69 Z/28
67 Vert RallySport
69 Vert
What else should I look at to confirm it's authenticity?
Also, assuming it is real what would the approximate value be?
Old Mar 23rd, 13, 01:50 PM
First is to verify the Vin # sequence in the other post...
We need to see pics of Power Disk Brake setup and both prop valves.
12-bolt rear end and need the codes and build dates.
Single Fuel Line.
Disk Brake Pedals
4-speed hole in floor and firewall.
Re-enforcement plate on passenger side.
YH Rims 15X7
Rear Bumper Guards
This is just a few that I can think of at this time.
Then we can go from there...on a value.
Old Mar 23rd, 13, 01:55 PM
restore-z28's Avatar
restore-z28 restore-z28 is offline
Sonny
Jeff is correct as we need more pics and information. You indicated a non original motor but does it still have all the other components on the engine IE: DZ carb, intake, exhaust manifolds, smog systems, date correct heads, water pump etc. Does the car have the original interior and YH rims? What is the condition of the interior? Any documentation? Prices vary significantly based on all these factors, hard to put a price on something with no pics and minimal information.
1970 Z28 Camaro
www.camaros.ca
www.bccamaroclub.com
Old Mar 29th, 13, 10:10 PM
AZreGuy AZreGuy is offline
Tech Team
Cliff
what are the differences in the drake pedals?
Your AZ Real Estate Guy
Old Mar 29th, 13, 11:22 PM
ZLP955 ZLP955 is online now
Tim
Z28 included power (front) disc brakes, so the pedal should have the circular insert like this:
(depending on additional options, it may also have a bright trim surrounding the pedal pad, as well)
'69 04A VN Z/28 69-69 715 with VE3. Ex-E/MP at Lions in LA.
Link to mark x22's excellent templates & diagrams:
http://s1218.photobucket.com/user/ZL...?sort=3&page=1
Team Camaro Tech > All Generations > What's it worth?      Current Topic: 1969 Camaro Z28 Value?
Location
Location
First Name
Human Verification
