89 CAMARO CHECK ENGINE LIGHT - Team Camaro Tech
Troubleshooting Diagnosing problems done here.
Thread Tools Display Modes
Old Feb 15th, 00, 07:26 PM
lgmoore lgmoore is offline
Exclamation
HI! I HAVE A 1989 MODEL 2.8 V6 CAMARO ,I ALSO LIVE IN SYDNEY,AUSTRALIA SO IT IS BEEN CONVERTED TO RHD.
THE PROBLEM IS WHEN THE I FIRST START UP THE CHECK ENGINE LIGHT STAY'S ON BUT DOES NOT SEEM TO AFFECT ANYTHING. IF I THEN TURN IGNITION OFF THE FUEL PUMP CONTINUES FOR ABOUT 5 SECS.THEN I RESTART AND EVERYTHING SEEMS OK AND THE LIGHT STAY'S OFF.ANY SUGGESTIONS??
THANKS GARY
Old Feb 15th, 00, 08:20 PM
davidpozzi davidpozzi is offline
David Pozzi
Post
Try getting the trouble codes out of the computer. Locate the aldl plug under the dash near the computer. On cars here, it's near the drivers right knee on a Left hand drive model. You connect a u shaped piece of paper clip between the upper right two contacts ignition off. Then turn the key to on. The light will blink 4 times then pause then 2 times. This "code" is 42! It will blink this code 3 times, then go on to blink out other trouble codes. Then finish with 42 three times again. 42 means no distributor signal because the engine is not running. Write them down and post them here and we will talk more. Also take a look at the engine oil pressure, how long it takes to come up when you start, how high is it? Check all vaccum lines too.
Team Camaro Tech > All Generations > Troubleshooting      Current Topic: 89 CAMARO CHECK ENGINE LIGHT
Location
Location
First Name
Human Verification
