| Team Camaro Tech Current Topic: Rob heater and dash lights working | ||
| Troubleshooting Diagnosing problems done here. |
Rob, thanks for all of the help. I checked all of the plugs and switches. A wire on the switch to the dash control was cut. I fixed that and it works fine. The dash lights work too. I could never get power at the fuse box . I took the screws out of fuse box and pulled it out from wall and cleaned it a little, screwed the box back in and got power. I don't knw what I did but it works and my wife thinks I am a genius. It probly worked all along and I just didn't know. Anyway thanks for your help. One more question. My back up lights do not work. Tail lights and brake lights work. I don't think the transmission is hooked up. I don't see any wires or plugs running from or to transmission. How hard is this to fix..It is a 4 speed. Thanks again. |
| Sponsored Links | ||
Advertisement | ||
The switch for the back-up lights is located on top of the steering column, foward of the ignition switch.
Larry |
No Sweat. "Genius" You did all the work,
I can't help you much with the back up lights, follow thge same principals as you did with the lights and heater |
| Sponsored Links | |
Advertisement | |
