68 Ragtop sane tire choice - Team Camaro Tech
Wheels & Tires What fits what?
Thread Tools Display Modes
Old Aug 28th, 13, 06:07 PM
kettbo kettbo is offline
George
Default 68 Ragtop sane tire choice
making a Day2 Cruiser, have 15x7 Rallys already powdercoated, ready to go.
Few choices in Raised White Letter tires and my car sure needs a little more zing like RWL can supply.
Seems the BFG 215/65/15 are backordered or worse
Looked at 225/60/15, shorter, wider....
Is anybody running these on all four corners? Have seen people where the 235/60 rubs in the front. Would like to rotate the tires. Eventually they will go on my 68 Corvette
Anybody with these tires on the car, post up a snapshot please!
George Kettler
US ARMY Retired, Scouts Out!
o 70 Elky 454/3000 stall/3.42 gears
1.632 60ft, 11.726 ET, 113.49mph
o 68 Vette 427, owner 23 years
o 68 Camaro Rallye Green Vert 327/2004R/3.73 http://www.camaros.net/forums/showth...183654&page=68
Old Aug 29th, 13, 10:26 AM
Dave69Z Dave69Z is offline
Default Re: 68 Ragtop sane tire choice
I have the 215/65/15's on 15x7 rallys in a stock suspension 69 z/28. If you look at my photo album you can see them there.
Old Aug 29th, 13, 05:22 PM
George
Dave,
THAT is the look....how much different would 225/60R15 look compared to the 215/65s? Do not want to add bulk. want LARGELY STOCK but sneak a bit more rubber in there
George Kettler
Old Aug 30th, 13, 05:31 AM
Im not sure how it would look from the side since they are shorter. I have seen themonthefront of cars and they look a little more agressive if viewed directly from the front since theyaare wider. Many people go the 235/60/15 route. good luck.
Old Aug 30th, 13, 07:15 AM
nblehm nblehm is offline
Tech Team
Nate
I thought I had a better pic but 225/60/15 t/a on the front on a 15x7. 1" lowering spring.
Old Aug 30th, 13, 10:10 PM
George
Thanks for the posts and the pics...hope we get a few other responses
I have always heard the 235/60 15 will rub to the inside. Also my pretty fiberglass on the 68 Vette when I swap on the TAs for driving vs bias ply redlines for show
George Kettler
Old Aug 31st, 13, 07:46 AM
Rarerat's Avatar
Rarerat Rarerat is offline
Nick
George,
here's a pic of my 68 with 7" rallys and 225 x 60's. They fit well with no rubbing. I did try a set of 235's up front but they rubbed the fender every time I hit a dip in the road. IMHO 225 60's on the rear will be way to small & look funny. I have a set of 235 60's on the rear of our 68 Vert and they even look a little small with the rounded the fender wells.
On my 69 I'm running 225 60's up front & 235 60's in the rear and they seem to fit the car pretty good, although when it's time for tires again I will probably go back to 215 65's..
I hope this helps & good luck...
Old Sep 1st, 13, 08:59 PM
George
Nick,
I sure helps!
Here is the Camaro years back with the FRONT stock off my 70 Elky. Elky was visiting the paint shop. 215/65s on Welds
275/60 DRs....way too big
lame 14" and 75 series 'may pop' tires....when I took the car apart, I saw how REALLY SCREWED UP the tires were.
hmmm, 225s do look good, serious look at 235 rears
George Kettler
Old Sep 2nd, 13, 08:01 AM
67Rally's Avatar
67Rally 67Rally is online now
Brent
225/60's will have about 5mm or 3/16" less sidewall from edge of rim to outside of tire compared to the 215/65.
If you're going to stagger (and therefore not be able to rotate tires) I would go with a wider rear like a 255/60. As long as the backspacing is correct.
Old Sep 3rd, 13, 11:19 AM
George
decisions, decisions.....
Met with pal Craig from Team Chevelle and local TCNWRacing site. He's a big fan of the Cooper Cobras. The 216/65R15 is available. Mickey Thompson does not make this size. oh hell
George Kettler
  #11
Old Sep 3rd, 13, 03:00 PM
cv2065's Avatar
cv2065 cv2065 is offline
Chad
If you want two BF Goodrich tires in 215/65/15's, I've got two brand new in the box that I was about to send back. I know that they are very hard to come by these days for whatever reason.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Wheels & Tires      Current Topic: 68 Ragtop sane tire choice
Location
Location
First Name
Human Verification
