need help with this VIN no. - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Mar 15th, 02, 10:18 AM
z/27 camaro z/27 camaro is offline
Mike
Default
hi guys
the VIN is 124870N557039
i'm pretty sure this is a 1970 BB Camaro,396 L78.
can we confirm this by the VIN?
thanks for the help.
69 Camaro RS/SS 350.
GM 2.02 angle plug heads.
223 dur/480 lift hyd cam.
69 z/28 alum high rise.
69 z/28 780 vac sec holly carb.
4 bolt mains,steel crank,forged flat top pistons.
Turbo 350 2800 stall with shift kit.
3:73 12 bolt posi.
functional cowl induction & ZL2 hood
Old Mar 15th, 02, 10:23 AM
elcamino elcamino is offline
Mike
Default
No, can't tell anything from the VIN. You need some kind of documentation (paper work) to tell anything about options etc).
124870N557039
1 - Chevrolet Division
24 - Camaro V8 base engine
87 - 2 dr hard top
0 - 1970
N - Norwood Ohio Assembly
557-30-Production sequential serial number
Old Mar 15th, 02, 10:24 AM
Jeff H Jeff H is offline
Default
No, the VIN doesn't help verify an SS or big block. The cowl tag should have something like Z27 or L78 or L34 on it somewhere. Get all the information from the cowl tag and post it so we can help.
Jeff H - 93 Indy 500 Pace Car driven daily, Hugger Orange 69 Z28 with JL8 brakes, cross-ram & GM fiberglass hood, TI setup, heater and radio delete, being restored
