| Team Camaro Tech Current Topic: Cowl Tag | ||
| Tag Team De-coding tags and numbers. |
I bought a 67 rs Camaro and the cowl tag was
damaged. I was wondering if anyone might know someone that makes reproductions. |
| Sponsored Links | ||
Advertisement | ||
I really appreciate your help. That really took a load off by back.
On the other forum, you asked how to tell if your car was a RS.
If you post your VIN and the info off of your cowl tag, we'll decode it for you. ------------------ Kurt S. www.camaros.org |
The problem is my cowl tag has been totaly distroyed. Thats why I asked if anyone new where to get one made. What are the numbers for that option?
my vin # is 124377N170516
would you mind decoding my dads?
09E U259 st6812437LOS04502 TR 725 R-R |
bIG bLOCK:
09E : assembly date, 5th week of september U259: Los Angeles work order # ST68-12437: 1968 2 door coupe LOS: assembled in Van Nuys, Los Angeles 04502: Fisher body number TR 725:red interior with standard bench R-R: Matador red upper and lower body color Post the Vin #'s to determine the engine, 123378L.... : L6 ; 124378L.... : V8 hope it helps |
Define 'destroyed'. Nothing at all left or not much left or partly legible?
Even part of the info would be helpful. Could you post the VIN for your dad's coupe? Thanks! ------------------ Kurt S. www.camaros.org |
124378L304724
What tells if it is an SS? The guy we bought it from is the second owner and he said it is a SS. It has all the trim to be and also the dashinsterments are for a SS. They are a tic-toc-tach |
#11
At one time someone stoll the car and try to
ripe the tag off. You cant read any thing. |
#12
Bummer on the tag.
On your dad's car, nothing on the tags will indicate a SS. Gotta go with physical evidence. What's the codes from the engine, trans, and rear? 10 or 12 bolt? Multileaf springs? ------------------ Kurt S. www.camaros.org |
| Sponsored Links | |
Advertisement | |
