| Team Camaro Tech Current Topic: Need Tag expert | ||
| Tag Team De-coding tags and numbers. |
I have tried to figure out this 69 Camaro I have which I took in trade. The tag reads ST69 12467 NOR 282 848 712 72 03B X11 It is orange with black convertible. Hide away lights. Has ss emblem. Has back-up lights. Engine code is MB 20353 Any info appreciated. Thank you. |
ST69=1969
12467=Camaro Convertible NOR=Norwood Ohio Assembly 282848=Body unit number 712=Black Bucket Seats 72=Hugger Orange 03B=Body Build date March 2nd week X11=Could be anything with the Z21 (or Z22) trim group, except a Z28 or big block. From a 6-cyl to a SS350, although COPO cars where sometimes built from bodies with the X11 code. The engine code you have where did you find it? Look here for more info; http://www.camaros.org/numbers.shtml [This message has been edited by elcamino (edited 05-15-99).] |
Thanks for the info. Any way to tell whether it's an original SS? I got numbers off front pad next to head
Can't tell if it's an SS from the trim tag.
The block #'s aren't the right format. They should be V0228HA. Could you recheck them? The car have disc brakes? 12 bolt? There are some other things to check also. Could you also post the VIN? Thanks! |
Another thing to look for is a fuel return line. If it is, indeed, an SS, it should have a return line (350ci/300HP all had Rochester Q-Jet (or Carter AFB) which use a fuel return line). The only exception to that would be a 396ci/375hp....
Steve [This message has been edited by mccorry (edited 05-18-99).] |
The problem with the fuel return line is that it was also used on the LM1 (255 hp) cars too. It is *very* difficult to tell a LM1 and an SS350 car apart. With the right options (disc brakes, stripe, dual exhaust) they would be identical except for the hood and the wheel/tire size.
Take a look at http://www.camaros.org/diffs69.shtml for more info. |
