Tag Team De-coding tags and numbers.
Old Jul 3rd, 99, 05:48 PM
Kenny Kenny is offline
Default
I have a 67 camaro and would like some help in decoding the cowl tag it reads
01D S303
ST 67-12637 LOS-15224 BODY PAINT
707-Z T-T
W 2LGS 35K
4P 5Y
Old Jul 4th, 99, 07:35 AM
elcamino elcamino is offline
Mike
Default
Double post, wasn't me. System gremlin!!
[This message has been edited by elcamino (edited 07-04-99).]
Mike
Default
01D S303
707-Z T-T
W 2LGS 35K
4P 5Y
Looks like a well equiped car!
01D=Body build date code 01=Jan D=4th weeks production.
S303=LA work order number
ST=STyle 67=1967 12637=Camaro Deluxe V8
LOS=Los Angles final assembly 15224=Body sequence and not supposed to match the VIN.
707-Z 707=Deluxe Vinyl trim Z=Strato Bucket seats(no headrests)
T-T=Capri cream, lower and upper colors
W 2LGS 35K 4P 5Y These are the option code groups, note 1 is always ommited for the first group.
Group 1
W=A02 Tinted Windshield only
Group 2
L=M20 or M21 4=speed
G=D55 Console
S=U73 Rear Antenna
Group 3
5=no 5 used could it be a S?
S=Z23 interior decor group
K=Z21 exterior trim group
Group 4
P=L30 327/275hp or L48 350/295hp
Group 5
Y=A39 Deluxe seat belts
I think this is a SS car because the L30 or L48 were SS engines. Someone else will have to confirm this, I can't lay my fingers on the facts sheet at the monment.
Old Jul 4th, 99, 09:36 AM
Default
I appreaciate the info and thought it was an SS car but needed confirmation any other information I would be very greatful
Old Jul 6th, 99, 08:05 AM
Jonesy Jonesy is online now
Mike
Default
Didn't all small block 67 Camaro SS come with a 350/295hp (L48)??
Old Jul 6th, 99, 09:26 AM
Kurt S Kurt S is offline
Default
ElCamino's decode was correct. And Jonesy is correct.
The L48 is an SS350 engine and the L30 is the 327/275hp.
So, from the codes you can't tell if it is a SS. Both a SS and a L30/M20 will have a 12 bolt.
There are a bunch of differences, all minor. See www.camaros.org/diffs67.shtml for the details.
Original glovebox sticker and speedo hole location are the two things to check that come to mind.
Do you have the original engine? What trans is in the car and what's the stamped #'s off of it?
Could you post the VIN and let us know what you find?
Thanks!
[This message has been edited by Kurt S (edited 07-06-99).]
Old Jul 6th, 99, 10:08 AM
Moris Moris is offline
Tech Team
Default
Kenny:
Nobody mention that the 707 trim code is for yellow custom buckets.
Old Aug 19th, 99, 04:22 PM
Default
Vin # 124377N244866
I don't have orig. engine but the car has a 12 bolt rear
