| Team Camaro Tech Current Topic: Early Block Stamping | ||
| Tag Team De-coding tags and numbers. |
Ebay Item 2497812419
Is this a little early for a 02D car VO0111DZ Casting Date L 18 8 |
| Sponsored Links | ||
Advertisement | ||
Something weird going on here, unless he made a mistake on the casting number.
This car should have a "3956618" block casting number. GM never even made the "010" block until mid April/69. The casting date makes no sense unless it is L-11-78, which means it is a restamp. The stamp date seems a little too early also, i have a car that is in my data base that is 530 cars earlier and the stamp is V0125DZ, casting date A-17-9. His ad shows 1 month between the casting and stamp date, i suppose that it could happen, but usually they are closer than that. Would like to see a picture of the pad. Just my .25 worth
1994 Lumina Z34, 2655lbs. 446" Small Block, Brodix Canted Valve, lenco 5 speed, 8.21/167 Best. New Bickle Cavalier, 1810lbs for 2010. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973. |
rszmjt That's my car in your data base and its a
618 block |
Hi Tony,
Forgot to add the 618 casting number in my post. This is kinda cool,-I have another car that is 100 cars before yours and the stamp is VO126DZ. Casting date is A-18-9 also a "618" block. Would you mind posting some of your other dates, heads, alt, starter etc? Thanks.
Don't mind at all heads A29 & A49 don't have
the alt. or starter wish I did.Intake was like dec 22 or 23 can't really remember.Still have the shocks too they are rears 23 69 & 25 69 only 1 front it's 36 69 the other one had been replaced.Rearend casting B 7 9 BU 02 21 G1 Hope this helps. Let me know if you need anything else.Transmission has been replaced with one from a 69 passenger car it's a M-20
'69 Frost Green Z/28 |
I would say you are correct, it's too early.
1969 Van Nuys RS Z/28. Protect-o-plate and chassis broadcast copy. Hugger Orange, original 711 interior, including carpet. Original drivetrain: DZ, M-20, 3:73 BO code peg leg. Flat hood, no spoilers. |
For some reason it seems all 02D cars have most things late. Mine has a March rear axle and a March VIN (by the tables that is). Most other people talking about 02D's here say the same thing.
"Government is not reason; it is not eloquent; it is force. Like fire, it is a dangerous servant and a fearful master." ..... George Washington Gary,TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original. |
My Norwood 02D Z/28 has B-19-9 heads, A27 intake, B-14/B-18 exhaust manifolds, 9B11 distributor, 9B19 alternator, 036 wiper motor, B17 tranny, 0219 axle, 45 master cylinder, 55 brake booster, 016 prop valve, 34 steering gear, 041 steering column, "A" radiator, and was shipped on 2/28/69. [img]graemlins/thumbsup.gif[/img]
JohnZ CRG '69 Z/28 Fathom Green |
Johnz were is the date code on the steering
box? |
Tony,
I'm not John Z but as I remember just pop the hood and look down at the steering box. There will be a Julian date code on the top of the box between two screw head looking things in the casting. Mine has a 346 Julian date. My master cylinder is dated 347. My booster is 356....... It's a Van Nuys car. Doug
| Sponsored Links | |
Advertisement | |
