Tag Team De-coding tags and numbers.
Old Sep 22nd, 99, 06:51 PM
Dalton Dalton is offline
Default
I'm looking to buy this Camaro & I need your help decoding the cowl tag.
ST 69 12437 NOR210322 BDY
TR 715 53 51 PNT
12 C X11
The VIN# 124379N567064
Also,is there a web site that I can check cowl tag codes?
Old Sep 23rd, 99, 06:34 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Default
It's a V8 coupe assembled in Ohio. Came with std blue int and I believe Blacier blue and dusk blue paint. Assembled 3rd wk in dec '68 and came with style trim x-11. your car was the 67964th '69 made. This site is a good ref for codes and also the CRG (Camaro Reserch Group) site. I am sure KurtS will provide the link when he reads your post.
...DjD
69RS Ragtop
www.fbody.com/members/topless69
Old Sep 23rd, 99, 12:04 PM
Jay Jay is offline
Tech Team
Default
check out http://holisticpage.com/camaro/parts_fs.htm
it has almost everything you'd every need to know
Old Sep 23rd, 99, 02:25 PM
Kurt S Kurt S is offline
Default
The VIN says it was a V8 and X11 means it had style trim and *could* be an RS but could not be a Z or a big block. So, that leaves the 327, the LM1, or the L48 (SS350). So does it have the original engine in it? What rearend? 2 fuel lines back to the tank?
Look at http://www.camaros.org/diffs69.shtml for more details.
Let us know what you find.
That's a really neat car because of the 2 tone paint. Still painted that way? BTW, those roof moldings are different from a vinyl top car.
Kurt S.
www.camaros.org
Old Sep 23rd, 99, 04:00 PM
mccorry's Avatar
mccorry mccorry is offline
Steve
Default
How so, Kurt? Completely different, or just in width?
Old Sep 23rd, 99, 06:38 PM
Default
Yes, it has the original 327 in it with 76k original miles. Has a 350 turbo transmission. The interior is black & the exterior has been painted red. Factory AC and power brakes. How much do you think it's worth?
Old Sep 24th, 99, 08:34 AM
Default
Dalton,
I have a favor to ask then: could you tell me the engine code stamped on the pad and if the VIN is stamped on the pad?
This is close to the end of the 327 in production before they changed to the 307 and we have very little info on 327 cars. Thanks.
Too bad on the colors in my opinion. Lots of red cars with black interiors. Not too many 2-tone blue ones.
On the value, condition is everything. Body, paint, interior, engine, etc. Hard to even hazard a guess without knowing a lot more about the car.
On the mouldings, I think they are different edges (since one was next to paint, the other was next to vinyl). Don't know for sure since I've never seen one. The parts manual specifically shows different part #'s.
Kurt S.
www.camaros.org
