Help decode 69 RS SS Conv. - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Aug 23rd, 04, 06:44 PM
67RS RAG 67RS RAG is offline
Post
I have been looking at this car. Can you guys help decode this
ST 69 12467 NOR110529 BDY
TR 711 76 B PNT
09C
VIN 124679N517563
No #'s on Engine, Tranny is not matching, rearend is a 12 bolt couldn't get the #'s
Old Aug 23rd, 04, 08:50 PM
Rsmith1969 Rsmith1969 is offline
Post
breaks down like this,
1 = Chevrolet
2 = Camaro
4 = 8-cylinder engine
67 = convertible body
9 = 1969 model year
N = Norwood, OH assembly plant
517563 = vehicle serial number sequence
Decode for body number: 110529
09C = Built the Third week of September.
69-12467 = Convertible.
NOR = Built in Norwood Ohio.
711 = Standard Black Bucket Seats.
76-B = Lower Color is Daytona Yellow and the Convertible Top Color is Black.
No X code on that tag ?
Mine is a 09C Car with an X code
1 or 2 Fuel Lines ?
Disk or Drum Brakes in front ?
Exhaust Bracket on drivers side frame behind real wheel ?
just some other things to look for to know if its a True RS/SS
Old Aug 24th, 04, 01:12 AM
69-Z11Pacer 69-Z11Pacer is offline
Bill
Post
Just an FYI - no reinforcement plate on the drivers-side frame rail on a 'vert. The rails were thicker and didn't need it. But like RSmith said, it should have a bracket (or the outline from one) to be an SS car (dual exhaust)... [img]graemlins/thumbsup.gif[/img]
Bill
Classsic Performance & Restoration
http://www.cpresto.com
Old Aug 24th, 04, 02:13 AM
elcamino elcamino is offline
Mike
Post
This car is 1968 built car, 17,563 car made. Yours may be sept of 1969 with a VIN seq in the 9N68xxxx?
X codes did not start till November 68 time frame
Old Aug 24th, 04, 05:15 AM
Jonesy's Avatar
Jonesy Jonesy is online now
Mike
Post
X codes started showing up on trim tags in December of 1968.
Team Camaro Gold Member #14
1967 Camaro RS/z28 - one of 602 made - SOLD
1969 Camaro RS/SS L48 4 speed
1974 Camaro LT-Z/28 4 speed 33K orig miles
1979 Camaro Z/28 36K orig miles
1984 Camaro z/28 LG4 auto
Old Aug 24th, 04, 05:03 PM
Post
I does have power discs. As for the fuel line it has a new single line. When asked he said that's how he bought it and it does look new. How can you tell if it did have two?
Also what part of the code tells you it's an RS. I checked to see the reverse light slots and they look to be factory cut. There is definitely no X code. I do have a pic of it if someone can host it. I didn't check for the exhaust bracket is it welded on what does it look like?
Old Aug 25th, 04, 04:32 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Post
There is no code for just the RS option on the cowl tag or in the VIN on 69's. Without a build sheet or original dealer order form you will need to see all the components in place to confirm the RS such as headlight washers, extra solenoid for the washers on the wiper motor, chrome trim around wheels, proper location of back up lights and the wire hole in the trunk that leads to them. RS badges on front grille, rear deck under the lock and on steering wheel etc.
good luck with it. [img]smile.gif[/img]
I can post your pic for you, just email it to me thru the little icon with the ? in it.
This is what the back up light wire hole looks like, (before I refinished my trunk).
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Aug 25th, 04, 11:19 AM
click's Avatar
Moderator .. Jim
Jim
Post
Here is his cowl tag for discussion:
Photos for viewing
Old Aug 26th, 04, 01:07 AM
69SSConvertible 69SSConvertible is offline
Post
Can anyone post a pic of that "extra solenoid" on the wiper motor for the washers? I would like to compare it to mine.
Thanks.
Old Aug 26th, 04, 01:27 AM
drdave69 drdave69 is offline
Post
The picture of the solenoid is in the above photo. It sits on top of the wiper motor with hoses attached to it.
Dave, member number 7704
2000 Dodge Viper GTS
Old Aug 26th, 04, 04:06 AM
click's Avatar
Moderator .. Jim
Jim
Post
here are a couple of pics. The mounted pic is from Steve McCory, a TC member here and this lone pic is my 'spare'
the wiper body itself has a different part number than a non RS model. Only difference folks have found is the 2 extra holes thru the wiper body for the screws that hold this solenoid on. [img]smile.gif[/img]
Photos for viewing
