| Team Camaro Tech Current Topic: easy head question | ||
| Tag Team De-coding tags and numbers. |
I think they came with the block...
block is 3932386 / v1220fl, so we know this is a 327/2bolt/flint/dec20/327-at and this is true up to this point because it was attached to a th350 (obviously factory because the seals were SO bad/leaky!) but what are the specs on these heads? from left to right there are a number of stampings/castings. 3998991 21 gm50 e42 the only thing not stock on this 69' motor is the 2 barrel is long gone and a new manifold was put on somewhere along it's journey. can you id the heads for me? thanks! ![]() ------------------ poor man's '69 with lots of road gunk underneath...but Im not gonna give up...ever!!! |
| Sponsored Links | ||
Advertisement | ||
This is all I could find: Not sure how accurate it is...
3998991....72-73...307/350......75cc chambers Go AF! ![]() ------------------ Joe WCA Member HwyStar@Rochester.rr.com '69 wallet crusher '97 Blazer - Bad wheel hop! |
Here you go. http://www.partscavengers.com/techli...adcastings.asp
They are 74.5 CC with 1.72" and 1.5" valves. Used on 307's and 350's from 1968 to 1979. |
| Sponsored Links | |
Advertisement | |
