91 Z28 issue - Team Camaro Tech
Third Generation 1982-1992
Thread Tools Display Modes
Old Jan 25th, 14, 08:20 AM
91 Z28 91 Z28 is offline
Default 91 Z28 issue
I recently picked up a 91 Z28, 305 tpi, the car starts fine and idles perfectly but when I put it in gear it stalls, I'm thinking it could be the egr valve, what do u guys think?
91 Z28 305 TPI
Old Jan 25th, 14, 09:39 AM
ZZ_430's Avatar
ZZ_430 ZZ_430 is online now
Don
Default Re: 91 Z28 issue
You might try looking at the IAC (idle air control) valve. The pintel can clog. Very common. Clean the tip and the passage in the throttle body with carb spray.
Also the throttle blades themselves.
Don ~ TC Member #15 ~ http://www.flickr.com/photos/46701464@N06/sets/
Don't mess with Texas!
Old Jan 25th, 14, 10:06 AM
Thanks, I'll give that a try
91 Z28 305 TPI
Old Jan 25th, 14, 10:20 AM
Obsessive Camaro Disorder Obsessive Camaro Disorder is offline
Tech Team
Jason
i had a bad ignition module that acted similar. you can have it checked at a parts store.
Old Mar 6th, 14, 02:45 PM
I had the car running last night and just let it idle to see if it would she a cel, it didn't but after so long idling it just stalled, it started right back up and idled for another while before it stalled again, anyone have any idea what could be wrong?
91 Z28 305 TPI
Old Mar 6th, 14, 03:10 PM
Everett#2390's Avatar
<Jake-68's rule
Temporally install a fuel pressure gauge on the rail fitting just to see if f/pump is still working.
Could either be the pump overheating with less than a 1/4 tank of fuel or the f/pump relay having burnt contacts internally due to the current drawn overheating the closed contacts.
Old Mar 6th, 14, 08:31 PM
Tech Team
Jason
what have you tried so far? Did you take the ignition module to be checked?
Old Mar 11th, 14, 04:56 PM
I have been working a lot lately and haven't had any time to spend at the car, hopefully gonna get at it the weekend.
91 Z28 305 TPI
Old Apr 7th, 14, 07:34 PM
Tech Team
Jason
Get things worked out?
Team Camaro Tech > Generation Specific Forums > Third Generation      Current Topic: 91 Z28 issue
Location
Location
First Name
Human Verification
