| Team Camaro Tech Current Topic: decoding | ||
| Tag Team De-coding tags and numbers. |
Please help. will somebody decode this for me? vin 124379n580559 cowl tag:
st69 12437 nor23288bdy tr 711 79 bpnt 01b x44 thanks ------------------ |
| Sponsored Links | ||
Advertisement | ||
124379n580559
1=Chevrolet 2=Camaro 4=8cyl 37=Coupe N=Norwood, Ohio (assembly plant) 580559= Unit number starting with 500000 st69 12437 nor23288bdy tr 711 79 bpnt 01b x44 12437= V8-Coupe NOR= Ohio 23288= assembly plant code 711= interior: black std. 79= Rallye green B= Black vinyl top 01B= Build date: 01= Jan, B= 2nd week of X44= Base Car thats all!!! ------------------ ...DjD Topless'69 rsss.fun@gte.com |
<BLOCKQUOTE>quote:</font><HR>Originally posted by DjD:
124379n580559 1=Chevrolet 2=Camaro 4=8cyl 37=Coupe N=Norwood, Ohio (assembly plant) 580559= Unit number starting with 500000 st69 12437 nor23288bdy tr 711 79 bpnt 01b x44 12437= V8-Coupe NOR= Ohio 23288= assembly plant code 711= interior: black std. 79= Rallye green B= Black vinyl top 01B= Build date: 01= Jan, B= 2nd week of X44= Base Car thats all!!! <HR></BLOCKQUOTE> Is there any way to find out what engine came out with the car? |
dupl
[This message has been edited by Kurt S (edited 02-26-2000).] |
Maybe. We know it wasn't a SS or Z. We should be able to narrow it down more.
What axle is in the car? The #'s from it will help tell if it is original. Multileaf springs? Disc brakes? Single or dual fuel lines? Also, could you recheck your NOR #? There should be 6 digits. ------------------ Kurt S. www.camaros.org |
<BLOCKQUOTE>quote:</font><HR>Originally posted by Kurt S:
Maybe. We know it wasn't a SS or Z. We should be able to narrow it down more. What axle is in the car? The #'s from it will help tell if it is original. Multileaf springs? Disc brakes? Single or dual fuel lines? Also, could you recheck your NOR #? There should be 6 digits. <HR></BLOCKQUOTE> It has a single fuel line & a single spring leaf in the rear. Drum brakes on the front. Try this # NOR232588BDY Thanks |
Single fuel line means it wasn't a Quadrajet engine. Monoleafs were used on the base engine vehicles, meaning it was a 327 or 307.
Your car was built just as they were starting to switch from the 327 to the 307. I'd guess it a 307 car, but since we don't have the start of 307's nailed down, it is a guess on my part. ------------------ Kurt S. www.camaros.org |
Single fuel line means it wasn't a Quadrajet engine. Monoleafs were used on the base engine vehicles, meaning it was a 327 or 307. Your car was built just as they were starting to switch from the 327 to the 307. I'd guess it a 307 car, but since we don't have the start of 307's nailed down, it is a guess on my part. <HR></BLOCKQUOTE> I was told the engine was a 1968 model 327. Can you check these block numbers for me? 18S267105 & T0627HK Thanks |
Ok, what you have here based on the numbers you just supplied is a 1968 327cu 250hp engine w/ powerglide 2sp tranny from a full size Chevrolet. Oh, it was built in the Towanda engine plant on June 27th. Oh and the S in 18S267105 means that the full size car that this engine was originally mated w/ was built in St. Louis. Hope this helps.
------------------ Bryan Shook Favorite Quote - Some people have shrinks. Some people have their garage. www.geocities.com/motorcity/speedway/6673 |
<BLOCKQUOTE>quote:</font><HR>Originally posted by elcamino72:
Ok, what you have here based on the numbers you just supplied is a 1968 327cu 250hp engine w/ powerglide 2sp tranny from a full size Chevrolet. Oh, it was built in the Towanda engine plant on June 27th. Oh and the S in 18S267105 means that the full size car that this engine was originally mated w/ was built in St. Louis. Hope this helps. <HR></BLOCKQUOTE>What trans came in this car from the factory by the numbers? Thanks |
#11
elcamino said....a 2 speed Powerglide auto...
#12
The powerglide mentioned by elcamino came behind that NOM 327.
Did the car have a console originally (special rivet/bolts hold the console to the floor, hard to duplicate, easy to see)? What size hole is in the tunnel? If the car was an automatic, it was powerglide. Manual could be a 3 or 4 speed Saginaw. ------------------ Kurt S. www.camaros.org |
| Sponsored Links | |
Advertisement | |
