69 Z28 NOR vs LOS built cars - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Jul 22nd, 03, 06:51 AM
Johnny in AZ Johnny in AZ is offline
John
Post
My question is:
What is the difference between NOR and LA built Z-28's
Did the two factories use the same "exact" parts to assemble the cars ?? I am asking this because I am looking into Intake manifolds and I see that some of them have the "snowflake" casting on them...Is it because cars built in Ohio had them and LA did not ???
Thanks...
John in AZ
<a href="http://pg.photos.yahoo.com/ph/johnotis/album?.dir=/31de&.src=ph&.tok=phBEazBBTa1v1kvG" target="_blank">http://pg.photos.yahoo.com/ph/johnotis/album?.dir=/31de&.src=ph&.tok=phBEazBBTa1v1kvG</a>
Old Jul 22nd, 03, 07:08 AM
HawaiianCamaro HawaiianCamaro is offline
Jeff
Post
they both should have the Winters foundry (snowflake) on them
Jeff
IF YOU DON'T STAND BEHIND OUR TROOPS,
PLEASE, FEEL FREE TO STAND IN FRONT OF THEM !!!
http://www.camaros.net
http://www.yenko.net
Old Jul 22nd, 03, 07:19 AM
Vintage 68's Avatar
John
Post
I have never seen a 1969 VN/LOS built Z-28 without the #3932472 Intake with a Winters Industries 'Snow-Flake' Logo on it. I don't know if anyone else ever cast these intakes for GM.
The 69's used the same style aluminum intake as the 67-68's (#3917610), but didn't use the Oil Fill Hole in the front (it was plugged) or the Bypass Hose (also plugged). There was a slight difference in the location of the Thermostat Hole for 69 also - it was centered on the Intake instead of offset to the Left or Drivers side of the manifold.
Hope this helps - post back with the casting numbers and dates if you can.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Jul 22nd, 03, 08:19 AM
John
Post
#'s matching except for Intake/Carb/Exhaust...
02D build date...look at my previous posts...
John...
Just trying to see if I can get this back to "bone stock"........
Old Jul 22nd, 03, 12:37 PM
William William is offline
Post
Both Camaro assembly plants were serviced by the same engine & axle plant.
Other than VIN stamping and PTB stamps I know of no differences between Norwood and Van Nuys.
William
CRG www.camaros.org
