power steering gear box # - Team Camaro Tech
Tag Team De-coding tags and numbers.
Thread Tools Display Modes
Old Mar 2nd, 03, 04:22 PM
z28rookie z28rookie is offline
Tech Team
Post
I purchased a fast ratio power steering gear box at Carlisle Pa. this last year to put in my 69 Z..now I am looking at it and seen the numbers and would like to know if it is the right one before removing the old one...
#5691676
39
and on the gearbox is three small numbers..*352*
what is that number?it has the rubber coupler for it.and the pitman arm.....I am changing over from std.
Old Mar 2nd, 03, 04:28 PM
Kurt S Kurt S is offline
Post
What's the #'s on the pad on the aluminum cover?
Kurt S.
CRG - www.camaros.org
Old Mar 2nd, 03, 04:50 PM
Tech Team
Post
OH BOY I REALLY DID NOT SEE ANY ON THE TOP OF IT...THE ONLY ONES I NOTICED WAS THE ONES ON THE SIDE OF IT...THE TOP IS SLIGHTLY DIFFERENT THEN THE STD GEARBOX.....AND IT HAS A LARGE S ON THE BOTTOM OF THE BOX FOR SAGANAW....HAVE TO LOOK BETTER...WILL GET BACK TOMORROW..SO IT SHOULD BE ON THE ALUM CAP...HOW LARGE A NUMBER? THANKS
Old Mar 3rd, 03, 02:38 PM
Tech Team
Post
HEADS UP:
HER ARE SOME NUMBERS I FOUND TODAY..(I NEEDED MY GLASSES).....
NUMBERS ON THE TOP OF THE GEARBOX(ALMUN.CAP)7812145....
PITMAN ARM 5679209A
GMT78
ANY THING YOU GUYS CAN COME UP WITH,WOULD BE A GREAT HELP...
Old Mar 3rd, 03, 05:56 PM
Post
All those #'s are just casting #'s. That box and cover were used for many years.
There's a stamped number on the pad on the cover which tell us the year at least.
Kurt S.
Old Mar 4th, 03, 02:15 AM
Tech Team
Post
THE ONLY OTHER THING IS A VERY SMALL NUMBER 352.....THANKS
Old Mar 4th, 03, 11:14 AM
Tech Team
Post
HER I GO AGAIN...LOOKED AT A 69 NOVA GEAR BOX THAT A FRIEND HAS..THE PITMAN ARM IS DIFFERENT THEN THE FAST RATIO BOX I GOT AT CARLISLE..SO IT MUST NOT HAVE COME OUT OF A CAMARO AS I WAS TOLD.THE GEAR BOXES ARE IDENTICLE,CASTING NUMBERS ETC...NOW....IS THE NOVA BOX THE SAME AS A CAMARO?IT TURNS LIKE 33/4 TURNS...THE CARLISLE ONE TURNS 3AND SLIGHT FRACTION(EXTRA 1/8)...........ALL KIND OF QUESTIONS FOR NOW........HOW MANY RATIOS WERE THERE?.AND CAN I INSTALL THE FAST RATIO AND PUT A CAMARO PITMAN ARM ON IT?AND SHOULD IT BE A 57/8 INCH PITMAN ARM?.(IS A 57/8 PITMAN A STD. ONE FOR CAMARO'S)...ARE THE OTHER COMPONENTS DIFFERENT WHEN CHANGING TO PS? THANKS THE ROOKIE
Old Mar 4th, 03, 11:18 AM
Tech Team
Post
Old Mar 4th, 03, 12:47 PM
Post
352 is the day, after that will be one more # which is the year.
They all fit, just put the right pitman arm on and go.
But the Z box was a whole turn faster.
See David Pozzi's site for more info.
Kurt S.
Old Mar 7th, 03, 04:10 AM
merch120 merch120 is offline
Post
Pitman arm is 3953225, forged arm is 3953227. Center to center measurement is 5.750".
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Tag Team      Current Topic: power steering gear box #
Location
Location
First Name
Human Verification
