How can you tell if its a repro Cowl Air Cleaner or GM? - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Apr 15th, 02, 05:38 PM
Jim J Jim J is offline
Tech Team
Default
Is there an easy way to identify an original Cowl Air Cleaner and not purchase a reproduction by mistake? Thank You for the help, Jim
Old Apr 16th, 02, 12:57 PM
KevinW's Avatar
KevinW KevinW is offline
Kevin
Default
Jim, there are definite differences, but I might be letting the cat out of the bag if I post them Anyone else have an opinion on this?
Kevin
69' SS-350 Convert, M20, 3.55 posi. Totally Disassembled & in boxes (I'm working on it!)
69'(Hugger Orange -originally, Burgundy now) Z-21 Convert 327/PG, 3.55 posi too! Driver
Old Apr 16th, 02, 05:49 PM
Tech Team
Default
Kevin, I didn't want to disrupt the earths balance. I was only asking because I didn't want to buy a GM and be told later that I purchased a reproduction. I promise I want tell anyone the secret. Jim
Old Apr 17th, 02, 03:35 AM
Unreal Unreal is offline
Gary
Default
Kevin,
If you tell me, I'll put the seatbelts in the mail!!!
Old Apr 17th, 02, 04:52 AM
Daytona Yellow 69 Z/28 Daytona Yellow 69 Z/28 is online now
Nick
Default
Heck I'll tell everyone.I didnt realize that it was suposed to be a secret.
The original ZL-2 air cleaners are flat on the bottom where the the filter sits. If you turn it over and look at the bottom its flat. Repo air cleaners have a groove in the bottom where the filter sits. Also original air cleaners have a definit flare on the sporkel were it attachs to the base. Repos only have a hint of this.
I hope this helps,
Nick
69 Z/28 X77 D80 83700 original miles,DZ 302, M-21, BU 373 Rear End, ZL-2 Ducted Hood, Daytona Yellow, Black Deluxe, Tilt, Factory AM/FM, Console Gauges.
http://community.webshots.com/user/x77d80
Old Apr 17th, 02, 06:31 AM
X77D80 X77D80 is offline
Default
This info has even been posted in magazines...
- John -
69 Z/28
69 Z11
Camaro Generations Member
WCA Member
Old Apr 17th, 02, 06:48 AM
KevinW's Avatar
Kevin
Default
Nick, I gotta go catch that cat now!
Nick is correct, original ones are flat on the bottom. GM service replacements and Chevelles from 1970 on and repros have the groove.
The valve cover breather tube on Z/28s and SS350s is 3/4" dia and has one 90 deg. bend. Repros have two 45 deg bends.
I'm pretty sure the SS396 and COPOs have a 1" dia breather tube and one 90 deg bend.
SS396 and SS350's (and Pace Cars) with Auto trans have the vacuum flap on the snout. Quite rare and not repro-ed.
The area around the carb, is smoother on the repros, I'm pretty sure. GMs have a lot of wrinkles in this area.
Hope that helps!
I hope none of you guys are going to the same swap meets as I and get that original $50 air cleaner before me!
Kevin
[This message has been edited by KevinW (edited 04-17-2002).]
