| Team Camaro Tech Current Topic: steering box leak | ||
| Tag Team De-coding tags and numbers. |
My 69 has been setting up for a while and after filling the steering pump with new oil, I noticed the box starting leaking after I turned the wheel while not running. Leaking at the top of the box near the coupler. Before I tackle the removal of the box, I have learned it is best to hear from someone that has done it before; it saves lots of headaches. Also is it rebuildable or should I just replace it with a new one?
1969 Camaro Z-11 Pace Car 350cu/300HP - Convertible RS/SS- Muncie M20 - posi 3.31, 12 bolt |
| Sponsored Links | ||
Advertisement | ||
They are not too hard to remove. You'll need a special tool to remove the Pitman Arm (available at local auto parts store for around $10). Otherwise, just remove the three bolts on the subframe, power steering hoses, and the the flex coupling bolts.
Several shops re-build 'em. The tricky thing is setting the lash correctly. Incorreclty set, it will wear fast. The cool thing with a rebuild is they can change the gear ratio to obtain a quicker turns. They can also improve the road feel. All this can be accomplished without changing the original look of the gearbox. Here's a couple of shops that can rebuild 'em: http://www.powersteering.com/ http://www.steeringgearrebuilders.co...s.html#classic I had Harry's rebuild my Chevelle's recently. Was leaking just like yours. Turned-out good. Hope this helps.
'69 RS Z28 Cortez Silver, Original Driveline, M22, 73K, Van Nuys Built, Chassis Broadcast Copy '69 Chevelle SS396 4SP, Fathom Green, Original Engine '06 GTO Brazen Orange, M6, 400HP LS2 http://www.littooy.com/hans/ |
Also, the gearbox and the aluminum cover are both date-coded and have GM PN#'s.
If that's important to you, be sure to tell the re-build shop you expect to get all the original external bolts & the original aluminum cover back/installed on the rebuilt gearbox...
Thanks for the quick response.
I'm glad to hear it is not that difficult. I am excited about the gear ratio change. Is there any thing to watch on the pitman arm alignment? Thanks again.
I just made sure my steering wheel was in the center position, front wheels straight, etc.
I'm going in for a full front-end alignment soon, so I figure I just need to get it close. Probably best to mark the relationship of the pitman arm to the gear box if you want to be safe.
Thanks again, I have contact your referenced sites and have gotten some good prices.
I will be removing the box ASAP
You shouldn't need a faster ratio. Your box should already be about 2 1/3 turns lock-to-lock. It's also a variable ratio gear, slow ratio in the center for driving straight, faster when turning. Good box.
If you're car's mostly original, I'd just have them restore it with original guts. |
| Sponsored Links | |
Advertisement | |
