booster & master - Team Camaro Tech
Old Mar 21st, 00, 09:33 PM
Jesses Jesses is offline
Red face
i tries to post this in another link by accident, here goes again:
hi all,
just pulled some spindles and calipers from a '70 chevelle 4 door for a bud in LV building a
'67. i know that everything between the ball joints are the same, but is the booster and
master the same? i also grabbed the porportioning valve and some small valve next to
the master, but want to know if my friend will need the booster and master. thanks,
Jesse
Old Mar 21st, 00, 10:05 PM
Kwaherei Kwaherei is offline
Post
You will need the master cylinder and porportioning valve from the other car! Maybe the booster also there may be difference in travel inside the booster. You will need to change the porportioning valve becasue the back brakes operate at lower preasure than front disc.
Old Mar 22nd, 00, 05:53 AM
Question
Ok so if i under stand you, the chevelle booster and master will fit the camaro setup? like the firewall will be the same? i already got the porportioning valve from the underside of the chassis, but i'm not sure what the little valve that was on the side of the master cylinder was for so i grabbed that too. but i can get teh booster and master from the junk yard from thesame chevelle for $50. if it will work, then i will probably grab it for my buddy in LV. he has priced a new booster at $129 i think.
thanks for replying. Jesse
Old Mar 23rd, 00, 07:38 PM
Post
Below
[This message has been edited by Kwaherei (edited 03-23-2000).]
Old Mar 23rd, 00, 07:56 PM
Post
http://www.oldengine.org/unfaq/leadfoot/discs.htm Check this page out,I think you will find it helpful!!!!!!!!!
Old Mar 24th, 00, 05:09 AM
Exclamation
thanks for the web site. it should be helpful. i have one other question though. i have beeen talking to my friend in LV and now found out that in deed the camaro is a rear steer. the Chevelle that i pulled the spindles from looks like a front steer(but i'm not sure. i have to go and check.)
now i have been told by several sourcesthat the 64-72 chevelle spindles fit hte 1st gen camaro. but now that i look at them, the caliper is on the wrong side if i were to flip around the spindles. i do remember that he backing plate and caliper mount bolt ontothe spindle, will i have to have my friend move the caliper mount around to accept the proper layout?
thanks again for the information... Jesse
Old Mar 24th, 00, 08:20 AM
snakedr snakedr is offline
Tech Team
Dave
Cool
The valve that is next to the master cylinder should be a metering valve to delay front brake application. This allows the rear drums time to overcome the spring tension.
Old Mar 24th, 00, 09:05 AM
Post
thanks for the info on the valve. now i'm trying to find out about the spindle compadibility...
thanks again, Jesse
Old Mar 24th, 00, 06:56 PM
davidpozzi davidpozzi is offline
David Pozzi
Post
I've got pics of most Camaro brake components on my web page.
http://ourworld.compuserve.com/homep...ge_transam.htm
Old Mar 25th, 00, 06:46 AM
Wink
david thanks again for the information. just wondering if the drum steering arm will fit on those chevelle spindles. thanks, Jesse
Old Mar 26th, 00, 04:23 PM
cam67 cam67 is offline
Jim
Post
The drum steering arms will work on the disc spindles.
Old Mar 26th, 00, 11:36 PM
Cool
now that is the reply i have been waiting for. mahalo(thanks in hawaiian)
