| Team Camaro Tech Current Topic: the control arms we all NEED | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
http://www.polepositionrp.com/first_...ebird-nova.htm only $99.95 per side. sweet. too bad i already have my new upper bushings and a balljoint that won't work with them. ------------------ 1971 Nova(looks like 69 camaro from underneath!) 355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way. see dirty pics here of a car that gets driven http://community.webshots.com/user/novaderrik [This message has been edited by novaderrik (edited 01-11-2003).] |
| Sponsored Links | ||
Advertisement | ||
these look great, and the price is nice too, has anyone got these on and how do they compare to some of the others on the market? ......speedy
Wow, those look really nice. I have the Global's on my ride, paid more for them than these. I wonder if they have the geometry figured out on these. Trick stuff.
they are supposedly built to stock specs, but with the way they are adjustable, you can make them damn near any shape/size you want. if you look thru some of their other control arms, they can be lengthened or shortened by a couple of inches just by turning the adjusters. looks like you could also crank in as much caster as you could ever need with them, too.
my only question is about the bumpstops- where are they? do you put a limiting strap on the lower control arm or just not worry about it? ------------------ 1971 Nova(looks like 69 camaro from underneath!) 355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way. see dirty pics here of a car that gets driven http://community.webshots.com/user/novaderrik |
Limiting straps...........
I like all the adjustments, but it looks like they might have some flex and the potential to pull apart at the bolt fastenings?
![]() ------------------ Don~ ZZ430DropTop ~~~~and~~~~ 70 RS |
Dont you guys think that on real roads not the race track those arms bolted with bolt on the shaft would detorate and wheel would flex front and back hence they move?
[This message has been edited by ismail (edited 01-11-2003).] [This message has been edited by ismail (edited 01-11-2003).] |
what do you think david, think these would work?
Hey Guys,
I was looking at some other forums and came across some GTO/LeMans owners running Pole Position a-arms. I know people are concerned about durability and about strength, but one gentlemen has been running the a-arms for about two years now and no problems. So, can these work, Pole Positions website shows a street camaro on the same page as the a-arms. I would think they have throughly tested them out before taking on the liability of selling them. What do you guys think? Here's the website: http://groups.msn.com/70MonteCarlo/arm.msnw Patrick |
when i first saw these arms, i thought maybe all the bolt locations could work loose over time. then i thought about it- the upper arm is pretty much along for the ride. most of the loads are handled by the lower arm, and the upper just essentially keeps the top of the spindle in the proper place.
#11
Lots of hardware that could come loose, but that probably isn't going to happen with careful assembly.
I do worry about lack of a bump stop in droop. If you have a short stiff front spring, it could come unseated by just jacking the car up. The angle of the ball joint flange looks rather flat in relation to the arms. I'd have to compare that to a stock A arm. I'm wondering if the upper ball joint angle is correct. David |
| Sponsored Links | |
Advertisement | |
