Old Dec 13th, 99, 07:14 AM
71 RS Z28 71 RS Z28 is offline
Default
What is the mesurement from backing plate to backing plate on a 2nd gen Camaro rear? I have a rear that is 50" from backing plate to backing plate and I would like to know if it would fit.
[This message has been edited by 71 RS Z28 (edited 12-13-99).]
Old Dec 13th, 99, 09:26 AM
MikeDF80 MikeDF80 is offline
Default
I am not sure about the backing plate distance, but they should be 61 inches from drum face to drum face. Thats one inch wider than first generation.
Old Dec 13th, 99, 10:29 AM
cardude cardude is offline
Default
By casting numbers, my 12 bolt is from a 70 year camaro and it's (approx) 55" from flange to flange. If stock, I'm not sure what that 50" diff. would be from. Has it possibly been modified (narrowed)?
Old Dec 14th, 99, 09:34 AM
Default
The rear that I have I think came from a 69 RS and I was wondering if I move the spring purches out would the rear still fit on my car.
Old Dec 17th, 99, 04:16 PM
Scooter Scooter is offline
Default
I'd be careful when moving spring perches. If not done correctly, your car can "dogtrack" or have all kinds of vibration/driveline problems.
If done properly, a 1st Gen rear would physically fit in a 2nd Gen car, but the stock wheels may not work. You would need wheels with a smaller backspacing measurement, or they could rub on the inside of the wheel wells, or even on the leaf springs.
70 & 1/2 RS
SB406 & M20 4spd
9" rear
70 Malibu 350/TH400
Gold member #103
[This message has been edited by Scooter (edited 12-17-99).]
