Old Feb 13th, 00, 04:31 PM
Black69 Black69 is offline
Dave
Question
Has anyone replaced the stock front sway bar with the hotchkis 1 1/4 replacement. Just wondering how much difference the new performance bar makes?
Old Feb 14th, 00, 06:43 AM
gheatly gheatly is offline
Post
The Hotchkis bar makes a HUGE difference. The entire front end is stiffer and more responsive.
Just make sure the rest of the suspension is in good shape. My front end had some slack I was able to trace to the steering box. It made the car dart around when I made even minor steering corrections. You can adjust the box to take up the slack, but I am upgrading to an AGR rebuilt quick ratio box. The car is on jack stands in the garage as I type this reply.
Old Feb 15th, 00, 06:36 AM
kwissman kwissman is offline
Post
I installed the bar and springs and it makes a giant difference. Between night and day. I would recommend the Hotchkis bar. It is light and does what it is supposed to.
Kent
67 SS 427
Old Feb 15th, 00, 01:56 PM
village idiot village idiot is offline
Post
I'm about to start a major rebuild of my 69. I'm going to start with the front end. Won't bore you here with a bunch of my plans. I see there was mention of the AGR quick ratio steering box. I'm not up on my steering boxes. Is the AGR quick ratio a manual box or is it a power steering box? I had thought about adding power steering to my car but if I can get the same steering response with a quick ratio I'll go that route maybe. Can anyone help me understand the difference in these, if indeed there are any?
Old Feb 15th, 00, 01:59 PM
Post
The AGR box is a 12:1 quick ratio power box. I'll let everyone know what its like after I finish installing it this week end.
Old Feb 18th, 00, 11:55 AM
JimM JimM is offline
Jim
Post
How much bigger is better? Most of the aftermarket replacements hi po bars are 1", same as a stock Z28 bar. I've also seen 1 1/8 and 1 1/4. Any opinion on the definition of too big?
Old Feb 18th, 00, 12:03 PM
69SSRS 69SSRS is offline
Post
Guys, if I'm not mistaken, the Hotchkis bar for 67-69 F-bodies is actually 1 1/8" in diameter. Check out their website www.hotchkisperformance.com. Looks like a good bar. Take care.
69 SSRS Frame-off Resto
81 Z-28 377ci Drag Car
Old Feb 18th, 00, 02:22 PM
ScottLD ScottLD is offline
Talking
Be aware that the Hotchkis bar at 1 1/8 inches is hollow. Most 1 inch bars are solid.
Scott
Old Feb 19th, 00, 03:13 PM
Post
The people at Guldstrand said that the Hotchkis swaybar was too thick, even though it was hollow. They recommend a 1 inch max diameter swaybar. I heard this AFTER I bought my Hotchkis bar. However, I bet the Hotchkis bar is half the weight of the standard 1 inch solid swaybar.
The AGR box and pump are great!! I finished the install today. The box is a high effort one like current model T/As and Z-28s. Much more effort than the stock box.
With my suspension upgrade almost complete, you can really feel the lack of camber gain in the stock suspension geometry in tight corners (upgrades = stiffer lowering springs, Hotchkis bar, AGR steering box and pump, 245/50/16 tires; poly graphite a-arm bushings are next). I can feel the car turning on the outer edge of the tire. It's kind of scary.
However, driving around town the combination of the new box and Hotchkis swaybar are a substantial improvement over the stock set-up. The car changes directions much faster and smoother than before.
Old Feb 19th, 00, 07:41 PM
davidpozzi davidpozzi is offline
David Pozzi
Post
If someone can give me the OD and ID or wall thickness of the Hotchkis bar, I can calculate the spring rate.
Old Feb 20th, 00, 07:49 AM
Dave
Question
So in everyone's opinion, is it best to stay with the original equipment or to go with the hotchkis bar?
I also understood that hotchkis has a solid bar at 1 1/4 and the hollow is 1 1/8. Anyone know for sure?
Old Feb 20th, 00, 09:34 AM
CarlC CarlC is offline
Post
davidpozzi-
I've been trying to get the numbers as well but no luck so far. It would be interesting to compare the weight/stiffness ratios. Maybe a good guess would be to take the length and weight of the bar and calculate a wall thickness? It would not be perfect but I bet you could come pretty close to a standard wall thinkness.
Old Feb 20th, 00, 09:59 AM
David Pozzi
Post
Carl,
Your suggestion sounds good. I'd imagine the hollow bar is equivalent to a one inch solid bar. I checked out the hotchkis springs- they rate 600 lbs per inch. that's a pretty racy spring rate for a small block. Plenty stiff. My old autocross springs were about 650 lbs. I passed my old 550 lb springs to a friend with a 69 Camaro and he likes 'em. so I guess springs in the range of 550 would be nice street springs, and 600 to 650 for track use, kinda stiff for street. Maybe 700+ would be race only.
Old Feb 21st, 00, 06:41 AM
Shawn Shawn is offline
Post
Gheatly-
So what do you think of the sway bar? You sounded happy with it until Guldstrand said it was too thick? Did they give a reason for not going above 1" ??? The other people that posted seem to like the Hotchkis bar as well...
Shawn Peterson
1969 Z28, 406SB
http://www.geocities.com/corsican69
Old Feb 21st, 00, 09:31 AM
Post
I am perfectly happy with the Hotchkis bar and I would definately upgrade the stock bar to something bigger. I like the weight savings of the hollow bar. My friend just got a 1 1/4 solid bar for his 72 T/A and that sucker is HEAVY.
I was able to slightly twist my stock bar with my arms. It was VERY flimsy. I don't think the stock bar does much in terms of performance.
Another thing about the bigger bar. It really tightens the front suspension up in terms of up and down travel. It was almost like adding springs with a higher spring rate. With the stock bar, I could push down on one of the front fenders and get the car bouncing a good inch or two. Now, I can hardly make it bounce at all. I can sit on the fender and it moves down maybe 1/2 an inch.
[This message has been edited by gheatly (edited 02-21-2000).]
