pulley removal for power steering pump - Team Camaro Tech
Thread Tools Display Modes
Old Jan 27th, 04, 05:25 AM
convertibleRS convertibleRS is offline
Tech Team
Post
Can anyone tell me how hard or easy it is to remove the pulley for the power steering pump in a '67? I need to change my pump, but I read a post that says you need some sort of tool to get the pulley off. If that's true, anyone know where to rent or buy one? Or can I just pry it off?
Thanks.
'67 Camaro Convertible Rally Sport<br />'03 Harley-Davidson Heritage Classic
Old Jan 27th, 04, 06:25 AM
ohcscott ohcscott is offline
Post
do not try to pry it off.
you can rent for free, or buy one, at autozone.
it is a simple operation with the correct tool.
If I didn't learn it from my my mentors, I learned it as a result.
my car
pleasurizer.com
Old Jan 27th, 04, 07:45 AM
Tech Team
Post
Thanks for the info.
Old Jan 27th, 04, 03:13 PM
68rs406 68rs406 is offline
Sean
Post
on my 68, the pulley just slid off. it had a flat on the shaft, i believe, or something like that, that held it in place, and the nut just keeps it on. i took my nut off and it came right off.
if 67's are the same, it may be easier than you think. good luck with it
Sean
1968 rs, with an old school, antiquated "junkyard, never even had the valve covers off" 354" SB2.2 pump gas motor........
"I aint never seen talking win me nothin'" -Marshawn Lynch
Old Jan 27th, 04, 06:12 PM
JIML82 JIML82 is offline
Post
All GM power steering pumps until 1975 had a tapered driveshaft with a key and nut that held the pulley in place. Remove the nut and the pulley should come right off. (It could have some rust holding it in place.)
If you have a 1975 or newer GM pump, then the pulley and pump driveshaft are different. They are an interference fit to each other. Then you must use a special puller tool that is designed to grip the pulley hub and thread into the end of the pump driveshaft. Never remove or install the pulley by reacting directly against the pump itself. You will break things inside the pump. You must use the proper tools that react against the driveshaft.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: pulley removal for power steering pump
Location
Location
First Name
Human Verification
