How to Adjust Manual Sterring Box on 69 - Team Camaro Tech
Old Nov 18th, 04, 03:56 AM
rEd69 rEd69 is offline
Post
Can any one fill me in on how to adjust a manual sterring box on a 1969 camaro.
Old Nov 18th, 04, 03:57 AM
Post
Thanks in advanced for any help!!!!
Old Nov 18th, 04, 06:45 AM
JimM JimM is offline
Jim
Post
The only adjustment is the screw/locknut on top, it adjusts the lash by pushing the sector gear down. When you screw the screw in, it gets tighter, but be careful, if you go too tight, the gear will want to "stick" on center, it will feel real funny and bad. Do it with the wheels in the air so it's really easy to turn the wheel.
Old Nov 18th, 04, 09:09 PM
jimfulco jimfulco is offline
Post
Center the steering. Loosen the lock nut, then turn the screw clockwise until it causes a slight binding when you turn the input shaft. Then turn the screw counterclockwise about 1/8-turn. Hold it still while you tighten the lock nut. Turn the input shaft a half-turn to either side & make sure it's not binding at those positions (sometimes they wear more at the center).
Old Nov 19th, 04, 06:34 AM
Post
Great, I'll try this weekend. Thanks for the information
Old Nov 21st, 04, 11:51 AM
JIML82 JIML82 is offline
Post
I have a paper on how to adjust your manual steering gear by feel in-car. It requires that you procede carefully since you must drive the vehicle after each adjustment.
Too much preload can result in your car having very little (or no) returnability (i.e. the steering wheel won't return to center).
The paper can be found at www.corvettefaq.com/A-car.asp and is the very last one.
Here is a direct link: http://www.corvettefaq.com/acar/Manu...tInVehicle.doc
