Ball Joints - Team Camaro Tech
Old Feb 16th, 01, 11:34 AM
67stock 67stock is offline
Post
Ok someone wanna give me some insight on how to install ball joints?
I don't want to take off the control arm but will if I have to.
It's the lower one I'm tryin to do.
Old Feb 16th, 01, 02:41 PM
pdq67 pdq67 is offline
Banned
Smile
You gotta either press it out and back in or knock it out and back in. IMHO, get the C-clamp hand balljoint press at a parts store for its rent or for free with the purchase of the balljoints. It will be easier. pdq67
Old Feb 18th, 01, 12:09 AM
Eric68 Eric68 is offline
Eric
Post
If you're going to do the lower I would suggest doing the upper while you're in there (if the lower is worn out the upper can't be far behind). In my opinion, the upper is much easier to replace than the lower anyway - just drill the rivets and it'll pop right out with a couple hammer blows. Good luck, ball joints are a greasy, nasty job.
Old Feb 18th, 01, 08:33 AM
davidpozzi davidpozzi is offline
David Pozzi
Post
I made my own balljoint press out of some square 2" X 6" tubing for the top and bottom, and 5/8" X 2" bar stock for the sides.
I placed a 3 ton bottle jack in the frame and used a piece of pipe over the bottom and used a smaller OD piece of pipe to press from the top of the ball joint to press it out.
You can reverse the pieces to press the new joint back in the arm.
This frame can be used as a utility press in your garage when you are done with the ball joints.
You can use this on the car if you get it high enough. The frame will hit the floor if you are too low.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
