Poly bushed spring shackles--how tight?? - Team Camaro Tech
Old Jul 28th, 00, 11:45 AM
pdq67 pdq67 is offline
Banned
Post
I got my springs in this afternoon, and now I don't know if I should tighten the red poly spring shackle bushings down until the shackles bottom out against the bolts "shoulders" or not??
I'm reusing my '67's stock shackles because they were fine. they were bottomed out with the rubber stock bushings but they seem way too "solid and tight" when I bottom the poly bushings.
Please advise. pdq67
Old Jul 28th, 00, 02:23 PM
mike_russell mike_russell is offline
Mike
Post
I Dont believe you bottom them out, I think there is a torque for those, Id recommend calling the company you bought them from and ask if they might know.
When I replaced mine I didnt torque them cause of the limited space, but I didnt bottom them out and have had no problems. i did this about a year ago.
If I find the answer in my spec book Ill let you know.
Good luck!
Old Jul 29th, 00, 04:29 AM
Banned
Post
Mike,
Thanks for the come back.
I'm going to back the nuts off the shackles and see what happens. I do know that I had to use a homemade "all-thread/washer/nut" press to put the frame bushings in and they were "SO" tight that I had to use 16" channel-locks to press the upper "half shackle" bolt in place. pdq67
Old Jul 31st, 00, 06:28 PM
69er 69er is offline
Post
When you're installing the frame bushings, you really need to clean out the holes with some 80 grit paper or the likes. There can be a lot of crud lurking inside where you can't see which would make the press tight. Bob
Old Aug 1st, 00, 07:08 AM
Banned
Post
69er,
I did and even "sandpapered" the shackle bolts. They are still "VERY" tight. Thanks for the comeback. pdq67
Old Aug 7th, 00, 07:30 AM
Post
When I did mine, The shackle bolts were of a shoulder type. You tightened them all the way against the shoulder.
Old Aug 7th, 00, 03:58 PM
Banned
Post
69er,
I'm going to try them "loose" first. Once I get my car running, I have feeling that everything will loosen up when the power hits the street. Then, I will torque them down until the shackles bottom. pdq67
Old Aug 8th, 00, 06:49 PM
Post
When you press them in you should leave them in the frig over night. That will shrink them down a little until they warm up again. Also put some silicone lube on them to help the press go easy.
Old Aug 10th, 00, 04:44 PM
Banned
Post
69er,
The "frig" idea was OK, I will remember it next time. Thanks. pdq67
