Old Feb 10th, 00, 06:22 PM
MadJu MadJu is offline
Post
I am getting ready to rebuild the front-end of my 68 SS big block. Does anybody have experience/oppinions about drop spindles vs. lowering springs?
Old Feb 10th, 00, 09:19 PM
davidpozzi davidpozzi is offline
David Pozzi
Post
1.Your camaro does not have enough negative camber gain under bump at stock ride height.
2.Cutting the springs to lower it will place the suspension in a better part of the curve where the upper A frame is starting to pull in more. This will actually improve your geometry a little.
3.The limiting factor is if you get too low the lower A frame will start to hit the sway bar mount. At that point though, you will be scraping the ground with the headers or trans.
4.Most drop spindles are heavy and are made of Cast Iron. with a steel spindle pressed in. Your factory spindles are made of forged steel.
5.Don't go so low you don't have adequate suspension travel. I have seen a lot of modified camaros lowered so much they are bouncing off the bump stops and it screws up the handling.
Old Feb 11th, 00, 07:27 AM
Post
Thanks for the input. I think I'll go with the lowering springs from Hotchkis. I also read a few posts back about being able to modify drum spindles to accept disc brakes. Anybody performed this? I don't want to buy new(or old) spindles if it isn't necessary.
Old Feb 11th, 00, 03:05 PM
CJ CJ is offline
Cris
Thumbs up
springs are definitly a great way to go. don't overlook the springs manufactured by Eibach. the quality is excellent as is the balance between performance and ride quality.i also suggest using a quality shock as Koni. i did use my drum spindle with a Bear brake kit along with the Pro-Motorsports spindle extender.
Old Feb 13th, 00, 07:13 AM
penguinjohn penguinjohn is offline
Post
Madju and pozzi,
I am also about to rebuild the front end on my 68 big block and am in need of some quality front end springs. I checked with both Eibach and Hotchkis, but neither have a set of springs for my car - They don't even have a functional part number anymore. The only place that I have found to carry any big block springs was Guldstrand, but I wanted a progressive rate system so I don't sacrifice ride quality. Do either of you have the part numbers for the springs you mentioned? If you could post them, it would be very appreciated. Thanks.
penguinjohn
Old Feb 13th, 00, 07:15 AM
Post
sorry, that post was for Madju and CJ, but if anyone has any suggestions, please feel free to post them.
Old Feb 13th, 00, 01:14 PM
David Pozzi
Post
The guldstrand springs I got years ago were for autocross, on a small block car. I had to cut them to a 13.5 inch free length to work on my 67 Camaro. The cut end is not the same as the normal end as it is not flattened on the end.
The moog #6041 is what I have. Two springs come in the box, so the number is for a pair. They rate out about 650 to 700 when cut as I have done. Probably 600 to 650 without cutting. I would guess you'd want to start about 1 1/2 inches taller for a big block.
Be aware, most Camaro springs settle, and I would not cut a set of springs shorter until they had been in the car for a couple of months. A good set of Eibach or Hyperco springs would set sooner.
Old Feb 13th, 00, 01:20 PM
David Pozzi
Post
The spindle for disc and drum are basically the same. Except the drum brake spindle has about a half inch longer boss where the brake shoe anchor pin screws in at the top. The threads are the same. Just cut it down with a hacksaw and grind it flat. when you bolt the brake caliper bracket on, check for straightness and shim or grind a little to get it right.
Old Feb 14th, 00, 02:41 PM
jmar jmar is offline
Tech Team
Post
I have a '69 Camaro with a 396. I also want to rebuild my front end and add new springs, probably in the Fall. I have a D&R Classic Automotive catalog that offers a set of coil springs for a big block '67-'69 at $54.95 / pair. The catalog says to order by engine size and year. Standard or heavy duty, with or without AC. It sounds just like what the doctor ordered. Anybody have any experience with these coil springs from D&R? Their order number is 800-472-6952. Their tech line is 630-393-0009. It seems like many of us have this common need... I hope D&R is the ticket! Looking forward to your replies. Jim
Old Feb 15th, 00, 02:07 PM
Post
I have also beein looking at custom springs from PST. Just waiting on an e-mail reply. I'll post the info as soon as I get it.
Old Feb 18th, 00, 11:50 AM
JimM JimM is offline
Jim
Post
I doin my front end, too. gonna cut the coils a turn and see where it sits, maybe cut some more, it's real high right now.
I live near D&R, and will call parts from there. No experience with thier springs, but they're good people to work with. Bought a set of headlight bezels today, and they let me pick thru the boxes to find the best ones. OER my A#$@%#@! these things look like they were painted by a chimp! Par for the course, I guess. At least they exist. Imagine what it's like to try to redo a 442!
Old Feb 19th, 00, 08:38 AM
Post
OK. I finially made up my mind and purchased some springs. Geez, all the deliberation on this site can really muddle up one's confidence in his selection! Anyways, I settled on the Guldstrand GT springs for my BB '68. The person who answered the phone (Dave I think his name was) was incredibly helpful and said that he would be more than happy to work with me to build the car exactly the way I wanted. They should be in about the middle of next week, and until then my hands and time will be tied up with disassembling my front end. Hope I don't have any homework this week! I'll let you guys know how they turn out.
penguinjohn
Old Feb 19th, 00, 05:13 PM
Post
Hey penguinjohn, could I get a little info about your springs? What is the spring rate? Do they lower the car any? I'm getting ready to order springs for my BB Camaro and am trying to get as much info as possible. Thanks and good luck man!
Old Feb 19th, 00, 05:59 PM
Post
MadJu,
I wish that I could give you alot of information to help you with your decision, but the guy I talked to at Guldstrand was adamant about not disclosing his spring rates with ANYONE. Get this - - I asked him about the spring rates that I had seen posted in an old issue of HOT ROD ("the brother's camaro" issue) and he told me that they were made up to protect them from someone ripping off their specs. Pretty smart! Anyways, they're the standard issue Grand Touring spring set from Guldstrand, at, I believe, somewhere around $159.95. He said that they came long (no length given) and that I will need to trim them to the proper ride height. I cleaned out the garage and moved the car in tonight, but could'nt start work because I couldn't find a spring compressor. I plan to install as new PST bushings, 1 1/8 sway bar, new springs, shocks and do the Guldstrand modification so it will probably be up on stands for the next week. I'll post a notice when I'm done and let everyone (sound's like there are alot of you guys in the same predicament) know how things turned out and all the specs you might need. I wish I had a spring compressor!
penguinjohn
Old Feb 19th, 00, 07:24 PM
David Pozzi
Post
A spring compressor should not be needed. Just place the car up on some good sturdy jackstands, disconnect the sway bar links, pull the shocks, place a floor jack under the lower A arm, and jack up a couple inches. break the lower ball joint loose and lower the jack. A floor jack with wheels is best. And place it 90 degrees to the car and close to the ball joint.
Adding to the dropped spindle info, I'm not totally against them. But they should be longer than stock (top to bottom) and made of something other than cast iron.
