| Team Camaro Tech Current Topic: V8 conversion | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
69 convertable has 6 cyl. drive line and springs. I have a 327 to put in the car. any input on this would be helpful.
------------------ Joe V. |
The engine mounts on the frame are different for the V8, Change those and the rest is cake!
Thanks for the help! Much appreciated!!!
I too am replacing a 6 cyl in my 67 with a 327. In addition to the engine mounts, radiator and springs, I am replacing the 5/16 fuel line with a 3/8 line. I think the original 6 cyls and 327's with 2 bbl carbs used 5/16 inch lines. If you plan on using a 4 bbl carb, you might want to consider using a 3/8 line.
I also replaced the six in my '69. You will need to change the radiator, fuel line (3/8), optional front springs (faster launch if you keep them), throttle arm, and the frame towers. The towers are $40 each at Year One, so I'd get them there. Also, if possible, keep the torque converter, because you'll have a higher stall speed with the small block. Good luck!
