Brake Pedal swap....help! - Team Camaro Tech
Old Mar 20th, 00, 10:38 AM
johnm johnm is offline
Tech Team
Post
I just bought a 69 with the small brake pedal, but i want to replace it with the large auto trans type. is this hard? how is it done? thanks
john
the car was originally a 4 speed but now has a 350 turbo trans.
Old Mar 20th, 00, 04:33 PM
Steve R Steve R is offline
Post
This is very easy. Crawl under your dash, look up at the pivot point. You will seee a pin that slides through brake and clutch pedal. At one end is a clip, disconnect the clip and slide the pin out. The pedals should come out with a slight pull. Reverse order to re-install. Power brake cars have a small bracket welded to it, if your pedal is from a manual brake car and you have power brakes make sure you have it. I belive it controls the power brake switch.
Steve R.
Old Mar 20th, 00, 05:20 PM
Joseph Joseph is offline
Post
I have a 69 auto brake pedal if you need it.
Joseph
Old Mar 21st, 00, 01:18 AM
Tech Team
Post
thanks guys, when i get a brake pedal assembly i will give it a try. i just discovered this board...very helpful.
Old Mar 21st, 00, 02:58 PM
Post
You can also use Nova pedals.
Steve R.
