| Team Camaro Tech Current Topic: Disc.Brake conversion | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
I have found a 72 nova with disc brakes. will this work on my 69 camaro? Thanks.
Yea, that setup will swap right over to the Camaro. The only thing you have to use off the Camaro is the piece bolted to the spindle that the steering is connected to. Just swap that to the Nova spindle.
WILL THIS PART BE ON MY DRUM SET UP
Yes. I don't know the name for the piece. It bolts to the spindle with two bolts, and then the steering linkage attaches to that piece. Compare the two setups and you will see the difference. The piece hangs off the back of the spindle on camaros, but off the front on chevelles. I am not sure which way the nova is setup. If it is like the chevelle you will have to switch the pieces. If it is already like the Camaro you don't have to.
Nova '68-'73or'74 whenever they changed body style uses the same frt. subframe so should be take off, then put on. Easy swap with those parts.
