poor burn out... - Team Camaro Tech
Old Apr 15th, 03, 01:53 PM
blackvi blackvi is offline
Jerry
Question
Hello Team!
Are poor brakes a reason why my 84 won't hold during a burn out? the car brakes in traffic and performs ok I guess, but the thing won't hold at all during burnouts. Whats the deal?!!?
Thanks in advance
Jerry!!
Jerry - Systems Specialist, IT consultant, Hot Rod Enthusiast -- Searching for a way to tap into the hidden strengths that all stroked SBC’s have. Then one day, an accidental overdose of Camaros.net altered my body chemistry.
Old Apr 16th, 03, 02:49 AM
chassisboy chassisboy is offline
Matt
Lightbulb
How do you have your line lock installed? The solenoid valve should be mounted after the proportioning valve with the front brake lines plumbed directly to the valve using a tee fitting. If the solenoid is mounted before the prop valve brake pressure will be applied to both the front and rear brakes. Also make sure that you pump the pedal a few times before pressing the switch. You need to build line pressure in the system to adequately lock the front calipers. Unfortunately the old style Hurst roll controls are no longer available. The allowed you to increase the pressure with the line lock on, pump through the valve. Almost all of the current designs offered do not have this feature.
'68 Camaro SS. Dealer for American made performance & restoration parts.
Check my site www.lyonsperformance.com
New Tool site!www.protoolzonline.com
Old Apr 16th, 03, 03:11 AM
Spames Spames is offline
Post
Does he even have a line lock?
Old Apr 16th, 03, 06:41 AM
Everett#2390's Avatar
<Jake 68's Rule
Cool
He obviously has what us 1/4 milers' want.........traction !!
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Apr 16th, 03, 09:41 AM
Silver69Camaro Silver69Camaro is offline
Matt Jones
Post
Yeah, burnouts are cool, but when I'm racin', I wish I couldn't do 'em!
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Old Apr 16th, 03, 04:04 PM
Jerry
Post
Hey Team!
I forgot to mention its a foot brake... no trans brake on it at all. I really dont want to consider it. I just wanted to know if I got better brakes or even rotors, would it help a burnout.
I used to do a pretty decent burnout with the radials on it, but I really did poorly when I put the MT's on it.
Any advice?
Old Apr 17th, 03, 12:59 AM
<Jake 68's Rule
Cool
Now the real reason comes out, MT's. It no wonder you can't spin'em. M/T's are sticky, more so than radials.
Old Apr 17th, 03, 04:29 PM
67camss/rs 67camss/rs is offline
Angry
Jerry,I don't see that you need to do a burn out. I'm guessing you are sitting in the water box trying to light the tires up. What I do,is roll thru the water and stop outside the box. Spin the tires a little to get some smoke. Do several spins to the staging beams( spin the tires than stop and do it again) and you should be good to go.I use 10 to 12 pounds of air in the slicks.
Gene
Old Apr 22nd, 03, 05:47 AM
rolling-robert's Avatar
rolling-robert rolling-robert is offline
robert
Post
i once made a nice burnout, but ever since when im driving and take of the thottle i can hear my rear brakes whine because they probably bent because of the heat...
i did it without a line lock also, so beware of those burnouts without line locks
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
Old Apr 22nd, 03, 10:30 PM
sik68 sik68 is offline
Steven
Post
If by change you have a proportioning valve, you might want to give it more front bias. Is your master cylinder properly filled?
Also, with the brakes on firmly but not too strong, try getting the rpms up quicker (jump on the throttle a little faster, and keep the burnout at a higher rpm. Ive noticed personally that I can hold the burnout better. If all this doesnt work and you still cant properly warm up the tires, you might have to get some skinnier ones.
1968 Camaro
355, Comp XR236R Solid Roller, Air Gap, Pro Systems Double Pumper,
TKO, 10lb flywheel, 3.73 rear, Global West Suspension, Corvette C5 brakes
3098 lbs (and falling!)
Old Apr 23rd, 03, 04:32 AM
robert
Post
the only reason to make a burnout is for making more trction, but if the tires are so sticky you cant burn them, isnt that just what u want?
making burnouts is like disrespecting your car.
Z28 1984
