Ralley Wheels &235/60/15 - Team Camaro Tech
Wheels & Tires What fits what?
Old Nov 27th, 00, 01:34 AM
johnnyr johnnyr is offline
Johnny
Question
Hey on a 67 Camaro will the 7" rim's with a 235/60/15 clear the Front & rear of a 67 camaro & not rub? I will be removing my air shocks when I put the 7" rims & 235/60/15 tires on the car! Thanks
johnny
Old Nov 27th, 00, 01:58 AM
kz1000ltd kz1000ltd is offline
Thumbs up
As long as your suspension is up to par, you should be ok. That's the size I have on the front of my 69, and they rubbed a bit before I redid the frontend, including new shocks and big block coil springs. That's about as wide as you can go, if you aren't sure, play it safe and go with 225's........KZ
John D. Smith
69' SS/396
www.geocities.com/kz1000ltd
Old Nov 27th, 00, 02:08 AM
Johnny
Post
will the 235/60/15 work in the rear with no airshocks & not rub? I have a 396 engine in the car & big block spring in the front!
johnny
Old Nov 27th, 00, 04:51 AM
Post
I run 235/60/15 front and 255/60/15 rear, KYB gas shocks, no hint of rubbing at all. Some say 275 will also work in the rear, but that's about max. Anything wider than that, and you'll need some air shocks or wheelwell massaging. KZ
John D. Smith
69' SS/396
