YA SS wheel backspacing? - Team Camaro Tech
Wheels & Tires What fits what?
Old Nov 25th, 03, 03:55 PM
KevinW's Avatar
KevinW KevinW is offline
Kevin
Post
I was looking at the Chevelle YA rims (5 spoke SS rims) 69 Camaro is listed at .40 backspacing and Chevelle is listed at .88 backspacing. Can you put Chevelle rims on a 69 Camaro? How big is the .48 difference? And don't say 1/2 an inch Does it effect anything?
Old Nov 26th, 03, 02:21 AM
green z green z is offline
Team Member
Post
Here is the problem I had with them. I bought 4 sswheels. 2 were YA and the other two were AO. Mounted the tires and bolted them on. Out for a test drive and I thought the wheels were going to fall off the car it was making so much noise. Now my 69 convt. is a standard car with drum brakes so you can't put some ss wheels on the front because the wheel weights hit the tie rod ends. Then I got to looking at the wheels and you can see the difference in the offset. So we rotated the tires front to back and all is ok.
67 royal plum L78 11.70's @115
69 RS Z28 cross-ram
68 convt. all orig 2nd owner
Old Nov 26th, 03, 11:37 AM
KevinW's Avatar
Kevin
Post
I will be puting them on a disc brake car, so that should not be an issue. So the the .88 backspace works fine on a 69?
Old Nov 27th, 03, 03:54 AM
Team Member
Post
What you need is for somone on this site to chime in who has the same coded ss wheels that you have or are going to buy just to be sure. I would like to say yes but I was suprised when I had the problem.I thought that the different code was just going into the next year never thinking it was a different back spacing
69 RS Z28 cross-ram
