Rear end GM posi additive - Team Camaro Tech
Thread Tools Display Modes
Old May 30th, 02, 05:57 PM
67vert 67vert is offline
Tech Team
Default
I was wondering if any one else has tried this! I have a posi in my 67 vert. When I bought it the rear end popped bad when turning. I bought the expensive GM additive and the popping went away. I change rear gears and added new oil. You guessed it the popping returned. Just for the heck of it, or because I pinch pennies, I used a grease suction gun and removed about two onces. I then replaced it with Marvel Mystery Oil. To my pleasure the posi popping went away. Any comments?
Old May 31st, 02, 01:56 AM
ORENCH ORENCH is offline
Bruno
Default
I had to use almost 2-1/2 small bottles of GM additive together with the GM gear lube to get rid of that nasty noise. http://www.camaros.net/forum/Forum9/HTML/004984.html
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
Old May 31st, 02, 04:58 AM
stingr69 stingr69 is offline
Default
it takes 2 bottles sometimes. I would not use anything else.
-Mark.
Old May 31st, 02, 05:44 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default
Agree with stingr dont be a chemist with expensive mechanical parts and lubes.
That marvel might not contain the additives for long wear in the rear end. Maybe pinching pennies is ok for some things but not lubes.
Id recommend series 2000 Amsoil 75w90, it already has the posi built into it and will run much cooler than petroleum lubes.
There is my 2 pennies worth
click
69RS 350/255 LM1,TH350,Dover White,Blue Vinyl top
F&R spoilers,pdb,ps,am/fm,4.10 Posi.,A/C,
fold down rear seat.
My RS www.brainerd.net/~knudsen/69RS
Old May 31st, 02, 06:41 AM
bspears bspears is offline
Default
New posi rearend made lots of noise. I took it back to Speed Merchant. The guy at the shop took a quick listen and said " forgot to put the additive in". He put some in and the sound went away. That stuff really works..
bob spears
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Rear end GM posi additive
Location
Location
First Name
Human Verification
