Number 1 Cylinder on Distributor Cap - Team Camaro Tech
Thread Tools Display Modes
Old Jan 21st, 05, 11:18 AM
grag grag is offline
Garry
Post
Where is Number 1 on a standard points style distributor? Got a picture?
Thanks!
'69 Z/28 Garnet Red
'66 Chevy II Nova SS L79 (project)
'68 Z/28 Matador red
www.ragzridez.com
Old Jan 21st, 05, 12:54 PM
BPOS BPOS is offline
Al
Post
The standard position is the first post to the driver's side of the points access window.
but
Not to confuse you, but you can drop the dist in anywhere you want as long as #1 piston is just shy of TDC firing. Wherever the rotor points, that is #1 and you wire the firing order clockwise from there.
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old Jan 21st, 05, 12:58 PM
Garry
Post
I understand.
Thanks!
'69 Z/28 Garnet Red
www.ragzridez.com
Old Jan 21st, 05, 12:59 PM
Al
Post
Old Jan 21st, 05, 04:02 PM
dnult dnult is offline
Post
As a general rule for GM, #1 position should roughtly point in the direction of number one cylinder. BPOS is right - technically it doesn't matter. Although, in some positions the vacuum canister can prevent you from adjusting the timing since it will bind up on the intake manifold or other stuff.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Jan 21st, 05, 10:32 PM
Garry
Post
Thanks for the help! Here is a recent pic.
'69 Z/28 Garnet Red
www.ragzridez.com
Old Jan 26th, 05, 01:55 PM
JohnZ JohnZ is offline
Team Member
John
Post
The #1 wire tower (by design) is the first one clockwise (toward the passenger side) from the adjustment window.
[img]graemlins/beers.gif[/img]
JohnZ
CRG
'69 Z/28 Fathom Green
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Number 1 Cylinder on Distributor Cap
Location
Location
First Name
Human Verification
