high compression 327s with camelhumps... who's pinging? - Team Camaro Tech
Old Jan 12th, 03, 05:24 PM
JIM68 JIM68 is offline
Default
i just wanted to see what static and dynamic compression ratios you guys with camelhumps are running, and also what intake valve closings your camshafts are at....
1968 Coupe, 327/210hp project in process. PS/PB, Factory AC, adding camelhumps and a CompCam XE262
1986 Chevy Stepside, dying 4.3L, TH-400, no A/C, 2wd, 1/4 million miles.
Old Jan 12th, 03, 05:58 PM
pdq67 pdq67 is offline
Banned
Default
Let's see... Isn't about 9.75 to 1CR. about the limit with the old heads guy's??? Unless you want to really play with your combination... pdq67
Old Jan 12th, 03, 08:45 PM
Default
i made a dynamic compression calculator using Excel.... the file is here
email me if you would rather me email it to you... file size is 274k, or i can zip it up.
[This message has been edited by JIM68 (edited 01-13-2003).]
Old Jan 13th, 03, 01:08 AM
Banned
Default
Great on the DCR thing!!!
Now there are two, your's and Pat Kelley's!!! pdq67
Old Jan 13th, 03, 02:59 AM
Default
thanks pdq67,
mine matchs Pats exactly if you enter zeros for the piston to wall clearance and the top ring land height.
Old Jan 13th, 03, 05:54 AM
Mark C Mark C is offline
Mark
Default
Wow 12.62 static, 11.69 dynamic, 91.99% trapped cylinder volume and 3.201 inch dynamic stroke with this coming years pistons. Guess I'm looking at 93 octane or better.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My 69 L48 - 350/300HP Engine
Old Jan 13th, 03, 11:00 AM
MoeSS396 MoeSS396 is offline
Default
It depends on the DCR. 7.5-1 with the old head design is all it wants on 91. I have heard many say the old 350HP 327 runs fine on 91 with the timing advanced. Thats a 290 duration cam and a 114LSA though, around 7.5-1 DCR.
