oil pan gasket - Team Camaro Tech
Old May 16th, 04, 02:55 AM
jumpstart jumpstart is offline
Question
Just wondering if anyones been brave enough to try to replace an oil pan gasket on a 350 in a 69 Camaro while still in the car? I know there's not enough room to drop and remove the pan while the engine is in the car, but I really don't want to pull it out. Looks like the pan gasket is leaking either at the rails or the timing cover/pan seal. The balancer seal was replaced last summer with a new SFI balancer so I know it's not grooved. Thanks for any advice.
Old May 16th, 04, 04:15 AM
67 Plum's Avatar
67 Plum 67 Plum is offline
Chad
Post
I pulled the pan on my 67 to replace a leaking rear main seal. It has a stock pan I had to pull mount bolts and raise engine an inch or so to get the pan out. Not as bad as I thought it was going to be.
Old May 16th, 04, 07:32 AM
Vintage 68's Avatar
Vintage 68 Vintage 68 is online now
John
Post
It can be done with the engine in car without much trouble.
Do a "search" on here for past posts on this -
A couple of quick "pointers" (others feel free to jump-in!);
- remove the distributor cap "before" jacking up the motor - have someone watching "up-top" if possible (or check often yourself) while jacking.
- raise the motor on a solid are of the block, Do Not raise by the Damper or you can damage the Damper and/or Crank.
- put solid supports (such as a couple of short pieces of 2x4) between the engine and frame mounts to prevent the engine from dropping at the wrong time.
- "clock" the Crankshaft for the most clearance in the front of the pan, this gets the front counterwieghts out of the way of the front pan lip - you can look in and see/do this from the front.
- While you in-there, check the Rear Main Seal, Oil Pick-up, Shaft Sleeve & ect.
- read all the info you can find on oil pan gasket replacement on here before you start...
Hope this helps;
John
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old May 16th, 04, 07:56 AM
BPOS BPOS is offline
Al
Post
...and consider using a one piece oil pan gasket. They are a bit on the spendy side, but work very well....
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old May 16th, 04, 11:20 AM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Post
If you use a one piece oil pan gasket make sure you use a thin coat of RTV on the corners of the four outside corners of the gasket. Also you can remove the idler arm from the frame and the front center link will come down to give the pan some clearance.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old May 16th, 04, 07:31 PM
jimfulco jimfulco is offline
Post
Turn the damper so the timing mark is at the 6:00 position for more clearance.
Old May 17th, 04, 03:16 AM
rojo rojo is online now
Robert
Post
If you have headers with factory A/C you may have to remove the passenger side header, at least I did. I used a couple of large 1/2" drive sockets instead of 2x4's under the motor mounts to let the engine rest on.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
'77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25
TC member #18
Old May 17th, 04, 05:10 AM
RickD RickD is offline
Post
Don't forget to unbolt the tranny mount. Also, undo the radiator hoses and see if there's enough slack in the ground cables/wiring.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
Old May 18th, 04, 02:27 AM
Eric68 Eric68 is offline
Eric
Post
All good advice so far . . . I found that clocking the crankshaft so the TDC mark on the balancer is at the 5:00 position is the best bet.
Also, if you use the Felpro one piece gasket (its a good gasket) don't use those little plastic guide-pin dealies on the front . . . they are very easy to snap off in the block when you are tring to put the oil pan back on.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old May 18th, 04, 05:52 AM
Vintage 68's Avatar
John
Post
- Uhhhh, maybe "loosen" the trans mount if necessary (they can flex enough to raise the front of the engine a couple inches) But, I would never "unbolt" it.
You need something to hold the engine in place besides the exhaust system and heater hoses...
An engine shifting to the rear on a jack could cause all kinds of wierd (read expensive and painfull) things to happen while you are under the car prying on the oil pan.
1968 Convertible
Some trucks
Old May 18th, 04, 06:20 AM
Post
I needed to unbolt with the poly mount !
Rick Dorion
