question of balance - Team Camaro Tech
Old Aug 7th, 01, 12:01 AM
carhodge carhodge is offline
Post
building a 383,is it ok to use a 6/34 instead of the 8in...?
67ssclone 327 4spd 410
Old Aug 7th, 01, 06:12 AM
Everett#2390's Avatar
<Jake 68's Rule
Cool
You can use either one, both have pros & cons.
6 3/4=faster to RPM, but will not absorb as much of the harmonics as 8 inch will. Has less kinetic energy than 8 in., think in terms of a flywheel.
8 = slower to RPM, but, reduces the amplitude of unbalance more than the smaller one.
For all practical purposes, 6 3/4 is good for the street and weekend duty. However, think of the 302, they came with 8-in., but then, they were made for 7-9K RPM.
Others here may have some good thoughts about this subject.
Everett 68/350/PG/11.90115mph
Old Aug 7th, 01, 06:33 AM
Grape Ape Grape Ape is offline
Post
In every test I've seen that swapped dampers (stock type), the larger ones always showed more power, even in acceleration tests. This tells me that even though the 8" is heavier, it helps in other ways to reduce power losses and in the end will make up for it's weight.
www.grapeaperacing.com
Old Aug 7th, 01, 08:19 AM
427TRI 427TRI is offline
Post
I use stock 8" on my spinning 427. I wouldnt go smaller unless its a drag car only.
Old Aug 7th, 01, 08:54 AM
JohnZ JohnZ is offline
Team Member
John
Post
You don't have a choice, unless you've spent the money for Mallory metal to internally balance your crank. Otherwise, you have to use the 8" 400 balancer, as it is offset-weighted for external balance (you also have to use an offset-weighted flexplate or flywheel with it).
JohnZ
'69 Z28 Fathom Green
Old Aug 7th, 01, 10:15 AM
<Jake 68's Rule
Cool
Some very good answers here, from all of you,
Your input on type of harmonic balancer to use?
Everett
Old Aug 7th, 01, 11:00 AM
camaroman7d camaroman7d is offline
Royce
Post
Hey JohnZ they make internally balanced 383 cranks now, so you don't have to run a 400 balancer (if you buy a internally balanced crank). Also there is no need for mallory metal with these cranks. Just thought I would point that out.
Royce
70 Camaro 383ci
69 Camaro 385ci
91 Camaro RS V8 (305 TBI)
Link to my 70
http://profiles.yahoo.com/camaroman7d
Old Aug 7th, 01, 11:56 AM
Post
Thanks guys,I think I will go with the 8".
Old Aug 7th, 01, 04:11 PM
b-boy b-boy is offline
Post
Johnz, You don't have a choice? I am using a 6.1" (that's right, 6.1") balancer on my 383 with no problems. It's from BHJ Dynamics inc., and is a ductile iron (nodular) hub and ring. It comes with 90 degree marks, 0-50 degree timing marks and "failsafe" ring mounting. It was $109, not much more than a stock unit and a whole lot better, in my opinion.
Old Aug 8th, 01, 07:27 AM
pdq67 pdq67 is offline
Banned
Question
Doesn't somebody make aftermarket 400 SB and 454 BB dampers w/ bolt in weights so that they can be used w/o the weight on an internally balanced engine and w/ the weight for an externally balanced engine??? pdq67
Old Aug 8th, 01, 08:08 PM
Lonnie67 Lonnie67 is offline
Post
pdq67, check out the ballancers at www.flatlanderracing.com I think they have what you want.
Lonnie
Oops, maybe not. I know I've seen them somewhere.
67 Camaro 410sb 11.63 @117.6
67 Camaro 388 12.10 @110.6
website
[This message has been edited by Lonnie67 (edited 08-08-2001).]
