BBC 396 vs 454... - Team Camaro Tech
Old Mar 4th, 00, 04:10 PM
Eric2ndGen Eric2ndGen is offline
Cool
Can a 396 Big Block be bored to 454 specs or larger (i.e. 396 bore is 4.094", 454 bore is 4.251")?
I have a 454 crank and rods, but only have access to a 396 block right now.
What is maximum bore that a 396 can take? Is it the exact same block as a 454 with a smaller bore?
Old Mar 4th, 00, 07:34 PM
Steve R Steve R is offline
Post
I believe if you install the 454 crank in the 396 you get a 427. You will probably not be able to overbore the 396 much more than .060.
Steve R.
Old Mar 4th, 00, 08:02 PM
davidpozzi davidpozzi is offline
David Pozzi
Post
396 is 4.094 bore 3.76 stroke
400 is 4.125 bore 3.76 stroke.
427 is 4.250 bore 3.76 stroke.
454 is 4.250 bore 4.00 stroke.
495 is 4.440 bore 4.00 stroke.
510 is 4.500 bore 4.00 stroke.
Old Mar 5th, 00, 01:36 PM
Post
davidpozzi was correct in indicating that the difference between a 396 and a 427 is BORE and difference between 396/427 and 454 is BORE and STROKE.
My question is: Is the 454 and 396 block exactly the same (except crank for stroke)- i.e. is the 396 bored out less at the factory than the 454 (i.e. can I bore is to 4.251" like a 454 and beyond?)- or does the 396 have thinner cylinder walls than the 454 to start with?
Old Mar 5th, 00, 02:16 PM
BillK BillK is offline
Post
Eric,
You cannot bore the 396 block out to 4.250...if you dont hit water...you will be awful close.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Old Mar 7th, 00, 06:20 AM
71 Camairo 71 Camairo is offline
Cool
To answer your ? No! You cannot bore a 396 out to a 454 size. As stated previously .060 is about the most that you can go. The blocks are the same with the exception of the bore of the cylinder when the cast was made. The walls will not allow for that much bore. If you wish to use the 454 crank and rods with the 396 block you can purchase a set of pistos with the corrocponding compression hieght and have a stroker 421 CI engine. I've seen it done. Just a little food for thought.
Old Mar 7th, 00, 06:57 AM
Angry
Thanks for the responses, it's too bad, I have access to a couple of 396 blocks and no 454s right now. Oh well...
Old Mar 13th, 00, 04:49 AM
GregGold GregGold is offline
Tech Team
Thumbs up
Hey Eric,
I had a .060 over 396 with stock type pistons, closed chambered heads, a good solid cam and a 750 dbl and open intake. I was able to walk away from the all-feared guy with the 427. They may not run quite as strong as a 454, but they are no slouch either. You have to think of winning as a package deal. Id consider going with the 396, since you have one, and using a taller gear. Good luck
Old Mar 17th, 00, 03:45 PM
CA420 CA420 is offline
Post
The 396 is nothing to be sad about. I would be happy to have one. I used to build 454's all day long for boats, they are strong motors butthink of all those SS396 cars out there. They are still tough contenders.
68 RS Ash Gold
Old Mar 19th, 00, 08:56 PM
Post
I have now come into a retired racing block (454) that I can use- thanks again for everyone's responses.
Old Mar 20th, 00, 01:14 PM
big gear head big gear head is online now
Freddie
Post
Some early 396 blocks can be bored to 4.250"(454). Knock out the center freeze plug, and if a standard pincel will fit between the cylinders you can't do it. But if the pincel will not fit between the cylinders you can. You should always have a block sonic checked before boring it.
