what's the difference between a posi and a locker rear end? - Team Camaro Tech
Thread Tools Display Modes
Old May 21st, 01, 05:59 PM
1968camaro123 1968camaro123 is offline
Don
Question
I'm just wondering what is the difference between a posi-traction rearend and a rearend with a locker?
Old May 21st, 01, 06:07 PM
big gear head big gear head is online now
Freddie
Post
A posi uses clutches to lock both axles together. The locker has drivers and couplers with teeth that lock together similar to a ratchet to lock the axles together. The locker is a more positive lock because the posi clutches can slip if the traction is unequal to the tires. Lockers are more noisy and can be iritating. The posi is easier to live with on the street.
'69 RS/SS396 pro street
427/4spd/9"
Old May 21st, 01, 07:31 PM
Don
Question
thanks alot, which one is more expensive? Because right now I only have a standard open rearend with 2:73 gearing and I'm going to be switching to some form of posi. I just want to know which is better, I'm planning on putting either 3:73's or 4:10's and I've heard that lockers are more common for off-roaders? Any help on my choice would be much appreciated.
Thanks in advance,
Donnie
Old May 22nd, 01, 03:44 AM
roger69 roger69 is offline
Post
What kind of driving do you do? If you live in town a locker will drive you crazy.
If its a weekend toy and you dont mind clunking and some fish tailing now and then go with the locker. All else use an eaton Posi.
Yes I have a Locker in my car, email me for details.
Old May 22nd, 01, 01:07 PM
Freddie
Post
I have the Detroit Locker in my car and I like it fine. It does make some noise, but I don't mind. It is different from the locker kits made by Power Trax and Trak-Tec. The Detroit locker is designed as a complete unit and is stronger than the kits, which go in a standard differential case. The Eaton is the best of the posi units. If you can put it in yourself and get the backlash and bearing preload right, that is what I would sugest.
427/4spd/9"
Old May 22nd, 01, 01:31 PM
69CamaroRacer 69CamaroRacer is offline
Cool
Hey 68Camaro,
I have the same rear end set up as u and I am going to an eaton posi with 3.73's it will give u tons of acceleration and be a good all aroun gear. I can't wait to get mine in
69 Camaro RS, 355ci mild cam, Preformer rpm intake, edelbrock 600 carb, 350 turbo w/ shift kit 2500 stall, 10 bolt 2.73 any more questions ask
Old May 22nd, 01, 02:53 PM
Don
Thumbs up
Okay, thanks alot
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: what's the difference between a posi and a locker rear end?
Location
Location
First Name
Human Verification
