| Team Camaro Tech Current Topic: Manifold leak? | ||
| Engine General Engine Discussion. |
What are the symptoms of a manifold leak? The gasket at the head looks normal when engine is cold but when it warms up, looks oily. If I stomp on the accelorator from a dead stop it pops or backfires.
Thanks for the advice. |
| Sponsored Links | ||
Advertisement | ||
for starters,get a can of spray carb cleaner(with the little jet hose)and spray around the manifold gaskets and other likely vaccum leak spots.if you hear the engine bog,you have probably found a leak.make sure you arent overspraying into the carb as it will have the same results.
sounds like timing tho! good luck! Eric
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms |
Thanks, sounds like a good ideal. I think you are right about the timing, I still have a point type ignition. I know I can upgade the point type to electronic with "Pertronix Ignitor" but I don't know if it is any good.
Thanks again! |
| Sponsored Links | |
Advertisement | |
