Is this a routine thing. I have checked for interferances When I assembled the engine. Its a 600 lift Hyd. crane can. I use 3/8 chro mo pushrods with guide plates and standard rockers.
67 prostreet BB Camaro
71 BB SS Chevelle (clone)
2002 35th anniv SS Z28 conv.
No it isn't. If they're bending you've got some sort of interference happening. Valve spring bind at full lift, retainer to valve guide at lift, valve to piston, etc. Something's happening and you need to do some investigating.
looks like retainer to guide. That would also explain why it blew out several valve seals. I checked for coil stack up that wasnt it. What are the odds that my cam is wiped?
Hopefully not, I would say the odds are in your favor the cam is okay. You're going to have to remove the heads anyway to machine the guides. Before you do anything I'd remove a spring or two and check to make sure the retainers are the problem before you tear into it (unless you can see that they are hitting with the springs on the heads).
Jody
[This message has been edited by Camcojb (edited 06-13-2002).]
I suppose careful for what you wish is in order. No bent pushrods but At least 2 lobes gone 1 grenaded lifter and exploratory surgery is on deck. any probs out there with the XE294H cam kits.
Related Threads
Team Camaro Tech
2.4M posts
82.9K members
Since 1998
