Gear ratio to suit 700r4 and 383 stroker - Team Camaro Tech
Thread Tools Display Modes
Old May 7th, 01, 06:33 PM
backfire backfire is offline
Post
Man I get excited thinking about doing some major stuff to my car. I need some advice. I have decided to go with a built up 700r4. My rear gears are 3.08. I need to know if cruising at 60mph will put my car under the power band of the motor.
Here is info on the engine: 383 stroker, edelbrock performer(not RPM) intake, comp cams extreme energy 268 cam, HEI ignition, S/R torquer heads, headers, Edelbrock 600 cfm carb, 2.5" exhaust, KB hyperuetectic pistons, roller tip rockers.
This engine was designed with off idle to 5500 Rpm power in mind. I want to confirm that it won't be a dog cuising if the rpms go toward the 1800 mark around 55mph, etc.
Yes, I drive it ALOT and need to get some decent gas mileage.
Thanks for the help,
Lance
Old May 7th, 01, 06:54 PM
boodlefoof boodlefoof is offline
John
Post
65mph would be around 1750rpm. That shouldn't be too too low for the motor. You will definately be getting good mileage. Even with a 3.73 gear you will only be turning 65mph at 2150rpm. Great for the highway either way.
Old May 7th, 01, 08:10 PM
DjD's Avatar
DjD DjD is offline
Dennis
Post
With 4:11's I turn 2500rpm @ 70mph. That's with 26.6" tall rear tires
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
Old May 8th, 01, 08:36 AM
69CamaroRacer 69CamaroRacer is offline
Post
go 411. with the overdrive u have it will charge down the road hard and still get good gas milage and have a good cruising rpm. Pluss u have a 3.08 first gear and it will realy get up!
69 Camaro RS, 355ci mild cam, Preformer rpm intake, edelbrock 600 carb, 350 turbo w/ shift kit 2500 stall, 10 bolt 2.73 any more questions ask
Old May 8th, 01, 05:33 PM
squarles squarles is offline
Post
I have 3.73 gears in my 67 with a 700R4 and they work good. I have thought about changing mine to 3.42 for better highway mileage. I wouldn't go lower than 3.73 if you do alot of highway cruising. I normally drive 75 to 80 mph which is 2800 to 3000 rpm with 26" tall tires. To be honest I would try the 3.08 out first before changing the gear.
What kind of converter are you using, I've got a 2400 lockup stall in mine and it works great. I would definitly use a lockup converter if I were you.
Stephen
67 RS/SS 350 700R4
69 SS clone unfinished
72 454 Weekend Racer
Old May 9th, 01, 04:55 AM
Post
Thanks for the advice,
I definitely plan on a lock up converter. I'll try out the current gear since will be the equivalent of 3.73s in the TH350 I have now.
LH
Old May 9th, 01, 08:57 AM
ilbl8 ilbl8 is offline
Post
with 3.08's you will have the best of both world's with a 700R4. great launche's and awsome freeway milage...IMHO
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Gear ratio to suit 700r4 and 383 stroker
Location
Location
First Name
Human Verification
